TSS and OSS replacement
AJRoo
Today I changed out my TSS and OSS sensors in the transmission. When I was done I noticed that the rpms were fluttering up and down about 200rpm. I gently drove about 10 minutes back home and had some sporadic shifts. By that I mean there was a few rough shifts, some that would have rpm hang, and some that just felt like the transmission couldn’t figure out what to do. Anyone have any ideas as to what could be causing this?
Consider This:
And this:
Ford Drive Cycle Information
For all other Ford Vehicles
Pre-Conditioning Requirements:
· Cold soak the vehicle for 8 hours
· No DTCs present
· Fuel fill between 15% & 85 %
Driving Procedure
1) Start the vehicle and idle for four (4) minutes.
2) Idle the vehicle in drive for 40 seconds (neutral for M/T).
3) Accelerate to 45 mph, using ¼ to ½ throttle (M/T stay in second gear
for at least 5 seconds). Accelerate for at least 10 seconds and shift
through to 5th gear.
4) Drive with a steady throttle at 45 mph for 30 seconds.
5) Stop the vehicle and idle in drive or neutral for 40 seconds.
6) Drive at speeds between 25 and 45 mph for 15 minutes.
Use ¼ to ½ throttle accelerations. Include the following conditions:
· At least 5 stops with ten seconds of idle time.
· At least 3 steady speed sections of 1 ½ minutes duration.
7) Drive the vehicle between 45 and 60 mph for 8 minutes (use high gear).
? Maintain a steady speed between 45 and 60 mph for 5 minutes.
9) Drive the vehicle between 45 and 60 mph for 8 minutes (use high gear).
10) Stop vehicle, idle for 40 seconds.
Edited by CARR142
added infomation
