2017EDGE Posted September 13, 2021 Report Share Posted September 13, 2021 I wanted to know if anyone has tapped into their turn signal to set up a switchback led strip. I have done it but it seems that the t/s has a constant current. So my relay isn't bein triggered as It should .. is their a second t/s wire that isn't getting constant voltage only when. You hit the turn signal .. thanks in advance. Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 13, 2021 Report Share Posted September 13, 2021 The turn signal circuit on the Edge uses a dual voltage setup, low voltage (5V i think) to activate the parking light and full voltage to activate the turn signal. The bulb itself is a single filament bulb. You can disable the "parking light" voltage using ForScan and then you'll get rid of the constant current, but you would also loose the "parking light" from the same circuit. Refer to this post. Though the side marker still functions as a parking light, so there would still be a constant power for parking light going into the headlamp assembly. Another source for the constant parking light is from the signature light in the bumper, it has 12V constant with ignition on and another constant with parking lights which causes the signature lights to dim when parking/head lights are on. 1 Quote Link to comment Share on other sites More sharing options...
2017EDGE Posted December 28, 2021 Author Report Share Posted December 28, 2021 Note to self buy a forscan Quote Link to comment Share on other sites More sharing options...
