Clicking noise from right front when turning
Rchalk
I have noticed a clicking noise at the right front corner of the car (2017 3.5L) if I start up from a stop with the wheels turned about half-lock to the left.  Does not occur on right turn from stop, and seems only to be noticeable when cooler temperature, below 40-45 degrees.  I have checked the obvious like lug nuts.  Is this a sign of an impending failure of a CV joint or similar?  Is there a lubricant I should be checking?  Thanks for your help.
