Change of TPMS sensor attachment type and place for 2006-2010 from rim to nipple
EDST777
Change of TPMS sensor attachment type and place for 2006-2010 from rim to nipple. It's possible? someone did it, partly on one wheel or all four wheels at once. The nipple-mounted sensors feel more practical and reliable to me. Thank you, any thoughts you may have.
I was also interested in clarifying whether the TPMS 315 Mhz 2011-2014 sensors are suitable for 2006-2010 cars, because there is also a similar frequency of 315 MHz, but only they differ in location or there are other differences?
Edited by EDST777
there are universal sensors such as from Schrader that you can use for the conversion. i think they are the same frequency 2007-2014, but not 100% sure.
the band style sensors on our 2007 are still original, and 3 out of 4 are functional. so 16+ years is a good haul. i think they are more active in later generations leading to quicker decline.
Edited by WWWPerfA_ZN0W
  • Thanks 1
1 hour ago, WWWPerfA_ZN0W said:
there are universal sensors such as from Schaffer that you can use for the conversion. i think they are the same frequency 2007-2014, but not 100% sure.
Thank you for your help, yes, I really noticed that the original sensors work properly for a very long time, while the same sensors "not original" can leave work earlier. In my question, I would like to clarify whether the sensors are suitable from 2011-14 (1.5) to 2006-10 (1.0), because there may be differences in receiver and frequency? As far as I know the attachment points in 1.0 and 1.5 of the TPMS sensors are different and the idea was to use the 1.5 sensor on the 1.0 car.
Edited by EDST777
from what i have seen, the TPMS system is very particular about the sensors it uses. so most likely, sensors from 2011-2014 will not work although specifications may seem compatible.
hence why i suggested universal sensors like these
https://www.amazon.com/Schrader-Sensor-33500-Universal-Programmable/dp/B0B581Y6RP
https://www.schradertpms.com/en/our-products/schrader-ez-sensor-familyr
https://www.schradertpms.com/sites/default/files/2020-07/2020 App Guide.pdf
Edge 2007 2010 W Chrome Wheels 315 6F2Z-1A189A 33500 33700
Edge 2007 2010 W/O Chrome Wheels 315 7L1Z-1A189A 33500 33700
if you want to get a tool also, the guide lists compatible tools.
  • Thanks 1
  • 1004ron changed the title to Change of TPMS sensor attachment type and place for 2006-2010 from rim to nipple
