bimap70455 Posted October 3, 2023 Report Share Posted October 3, 2023 (edited) Hello. I am doing my front struts this weekend on my 2013 3.5L AWD w/ 20" wheels and am looking for the workshop manual for the front strut assembly that shows the torque specs. I am found a handful of various ones, but some seem to be conflicting. I was able to find a document for a 2009, but can someone confirm these are the same? Per this document: Ford Workshop Service and Repair Manuals > Edge AWD V6-3.5L (2009) > Steering and Suspension | Suspension | Suspension Strut / Shock Absorber | Component Information | Service and Repair | Removal and Replacement (workshop-manuals.com) Top rod nut to piston: 85 lb-ft 4 upper nuts: 26 lb-ft lower flag bolts: 166 lb-ft I would very thankful if someone has the entire procedure for the 2013 Edge. Of course, unless the one above is the same. Thank you! DKM Edited October 3, 2023 by bimap70455 Quote Link to comment Share on other sites More sharing options...
Haz Posted October 3, 2023 Report Share Posted October 3, 2023 Welcome to the Forum, bimap70455 ! From the 2013 Edge Workshop Manual... Document download links> Front Shock Absorber and Spring Assembly - Removal and Installation - 2013 Edge Workshop Manual.pdf Front Shock Absorber and Spring Assembly - R & I Enhanced Image - 2013 Edge Workshop Manual.pdf Shock Absorber and Spring Assembly - Disassembly & Assembly - 2013 Edge Workshop Manual.pdf Shock Absorber and Spring Assembly - D & A Enhanced Image - 2013 Edge Workshop Manual.pdf Cowl Panel Grille - Removal and Installation - 2013 Edge Workshop Manual.pdf Cowl Panel Grille - R & I Enhanced Image - 2013 Edge Workshop Manual.pdf Good luck! 1 Quote Link to comment Share on other sites More sharing options...
bimap70455 Posted October 3, 2023 Author Report Share Posted October 3, 2023 I appreciate the quick response! Thank you very much! DKM Quote Link to comment Share on other sites More sharing options...
