Suspension LIFT
bgerman
My Edge came with the 'towing package', with 1.25" receiver and 4 pin connector. To make it a real tow vehicle:
Installer had to: cut off factory hitch, install new 2" hitch with 6-pin connector, install electronic brake controller, rewire connector and add wiring (at least one new wire from the tail light) for brake controller.
What I DON'T like with the 2" receiver is poor ground clearance - 11".
Would like to raise rear end 1-2". Not a lot, but it will make a big difference when off-road or towing. Motorcycle carrier drags bad.
Coil springs, I think. Can you buy a spacer?
I don't know what I'm talking about on this subject.
See photos.
Edited by bgerman
My Edge came with the 'towing package', with 1.25" receiver and 4 pin connecter. To make it a real tow vehicle:
See photos.
Google - Coil Spring Spacers
and you'll end up with rubber inserts. They are terrible, they fall out and they are hard on the coils. Get a proper spacer made. Aluminum works well. I haven't looked at the coils, but I am sure it can be done. I had a buddy make a set for my VW and it works great. In case your wondering, Jetta's & Golf's of my vintage have terrible ground clearance ( 4.5" ). The lowest point is a cast aluminum oil pan. Skid plate and a lift and all is well. Better in the snow too !
....um, they make ones from all sorts of materials too....
