MLLI18 Posted September 29, 2024 Report Share Posted September 29, 2024 I just replaced the PDU fluid in my 2020 Edge and wanted to detail my experience. I bought it new (Titanium with the Elite Package) and am trying to maximize its life by replacing all the fluids I can regularly. I had the PTU fluid replaced at a dealership when I went for a warranty issue with the touchscreen at 30000 mi. I bought the M/C fluid and decided to have Ford replace it, I paid 45 bucks for the fluid and Ford charged 130 for the change. For the RDU @ 36000 mi, I decided to replace the fluid. I didn't jack up the car, I just crawled under and kept it level. To remove the filler plug on the rear diff, I had to buy a slim "3/8" "breaker bar" from AMZ for ten bucks because there was very little clearance between a rear cross member and the fill plug. With this small wrench, I could remove the filler plug using a small pipe for leverage with no problem. The drain was easily accessible with a 3/8" rachet. The drain plug had a good amount of debris on the magnet and the fluid was very dark but I guess this is normal for break-in as my Subaru Forester had the RDU fluid in a similar condition at the same mileage when I changed it. I used Permatex high temp on the plugs and pumped the new fluid from the oil bottle using a screw-on pump from AMZ that worked great. I used about 3/4 of a Qt. which makes sense because the capacity is 28 oz +/- 1oz. I filled it until it started draining from the fill plug. Then I torqued the drain plug to 20 ft-lbs and used Permatex high temp on threads. Hope this helps - Peace. 6 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 29, 2024 Report Share Posted September 29, 2024 Thanks for sharing. I would like to replace my fluid soon. Quote Link to comment Share on other sites More sharing options...
Biker Posted October 4, 2024 Report Share Posted October 4, 2024 (edited) On 9/28/2024 at 9:36 PM, MLLI18 said: I just replaced the PDU fluid in my 2020 Edge and wanted to detail my experience. I bought it new (Titanium with the Elite Package) and am trying to maximize its life by replacing all the fluids I can regularly. I had the PTU fluid replaced at a dealership when I went for a warranty issue with the touchscreen at 30000 mi. I bought the M/C fluid and decided to have Ford replace it, I paid 45 bucks for the fluid and Ford charged 130 for the change. For the RDU @ 36000 mi, I decided to replace the fluid. I didn't jack up the car, I just crawled under and kept it level. To remove the filler plug on the rear diff, I had to buy a slim "3/8" "breaker bar" from AMZ for ten bucks because there was very little clearance between a rear cross member and the fill plug. With this small wrench, I could remove the filler plug using a small pipe for leverage with no problem. The drain was easily accessible with a 3/8" rachet. The drain plug had a good amount of debris on the magnet and the fluid was very dark but I guess this is normal for break-in as my Subaru Forester had the RDU fluid in a similar condition at the same mileage when I changed it. I used Permatex high temp on the plugs and pumped the new fluid from the oil bottle using a screw-on pump from AMZ that worked great. I used about 3/4 of a Qt. which makes sense because the capacity is 28 oz +/- 1oz. I filled it until it started draining from the fill plug. Then I torqued the drain plug to 20 ft-lbs and used Permatex high temp on threads. Hope this helps - Peace. Thanks for the write-up. I'm doing mine tomorrow while I have it in the air for the trans fluid. Edited December 10, 2024 by Biker Quote Link to comment Share on other sites More sharing options...
chipdog4 Posted December 9, 2024 Report Share Posted December 9, 2024 Yeah, there's very little clearance for a tool to get the fill plug out. Here's what I had and used when I do mine. 3 Quote Link to comment Share on other sites More sharing options...
MLLI18 Posted December 9, 2024 Author Report Share Posted December 9, 2024 Socket cap set hmm - I was trying to figure out what tool to search for, good to know. I saw a serpentine belt wrench at Harbor Freight that would work too. 1 Quote Link to comment Share on other sites More sharing options...
Biker Posted December 10, 2024 Report Share Posted December 10, 2024 I used an extension with a wobble drive ball end. No need to try and fit between the plug and crossmember. You can also pry the RDU itself down a bit on its rubber mounts to get a better shot at it. 2 Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted August 17 Report Share Posted August 17 I just did my RDU, PTU and a transmission drain and fill the past few days. I just passed the 20k mark on my 2023 ST. The RDU fluid was ok, but honestly it didn't need to go any longer. I put in a few more oz than I took out. The PTU on my vehicle has no drain plug and it is different than all the videos out there that I can find to do a drill and tap. With not being sure where to put a drain plug I pulled/sucked out 350ml and put in 500 ml. Again they shorted me on fluid. The PTU fluid looked good, I was really pleased to see that. I replaced 5 quarts of transmission fluid and it looked in really good shape. I was worried reading all the concerns with the RDU, PTU and transmission. As little as this all cost me in fluids, probably about $120 in total, I think it is worth doing every 20k or less as the RDU fluid definitely needed to be replaced, and only being able to get half the fluid in the PTU. I used the Motorcraft fluids for the RDU and PTU and used Valvoline ULV fluid for the transmission. I bought the Motorcraft fluids on Amazon and the transmission fluid on Rockauto. 3 Quote Link to comment Share on other sites More sharing options...
