Transmission warranty and tune?
rlarson69
Hey everyone,
I have a 2020 Ford Edge St with several upgrades and a tune included. I purchased this four months ago and bought the extended warranty. Now, after the tune, I can return it to stock, but the dealership will know it's been programmed, and I got the warranty mainly for the transmission.
Since the dealership will know if I ever bring it with a problem will this warranty be any good? I am debating canceling it.
  • 1004ron changed the title to Transmission warranty and tune?
  • 2 months later...
At worst, the only warranty denial Ford can apply is if they can show if the tune was the result of the engine or engine-related part failure.  All other warranty items will still be covered.  Doesn't matter if you have the extended warranty or not.
Now, if Ford says that's the issue / reason, you are really out of luck unless you want to fight Ford Corporate lawyers.  Depends on your Dealer as they have discretion on informing Ford regarding issues and warranty work.
