TSB 20-2190 DIY
w102acd
We recently bought a 2019 Ford Edge ST from my in laws.  I was expecting it to have the 8F35 tranny, but it has the 8F57.
It was having shifting issues (maybe 4-5 with some "flaring").  My in laws weren't sure when the tranny fluid was changed so did that (and it didn't look too bad).  I also reset the adaptive tables in FORScan and this made a huge difference!
My question:
In TSB 20-2190, it says "Reprogram the PCM using the latest software...".  Is this different than resetting the adaptive tables?
If it is different, is there a way for me to see if this has been done?  I have a laptop, cable, and FORScan extended license.
If it hasn't been done, is this something I can do with FORScan?
Since it's good after the adaptive table reset, should I bother with this TSB?
Thanks!
ForScan can flash the PCM firmware. But you will need a paid license, a very good wired adapter, and to know which Firmware versions are required.
