Hollywood1 Posted August 20, 2025 Report Share Posted August 20, 2025 I have a 2024 Edge ST and I would like to add the factory perimeter alarm ML3Z-19A361-A. Does anyone know if it’s a simple plug and play or if I need to get it coded? TIA Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 27, 2025 Report Share Posted August 27, 2025 According to Levittown Ford, adding the factory perimeter alarm to a 2024 Edge ST with the part number ML3Z-19A361-A is NOT a simple plug-and-play installation and DOES requires dealer programming. 1 Quote Link to comment Share on other sites More sharing options...
Hollywood1 Posted August 30, 2025 Author Report Share Posted August 30, 2025 Thank you. I don’t mind paying to have it activated but I can’t stomach paying to get such a simple thing installed. I can’t even find instructions for it. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 30, 2025 Report Share Posted August 30, 2025 Your ST should already have a Perimeter alarm. The only function the VSS would add to your ST is the shock sensor. I found 2023 installation instructions (here) and no special programming is required for VSS functions since if already have the key fob remote start from the factory. 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 30, 2025 Report Share Posted August 30, 2025 Whoa, ho, ho. After reading Omar302's post, I did some more digging. Seems Levittown was wrong. (But not me, of course .... :-) Here's what I'm finding now; "ML3Z-19A361-A is the part number for the Ford Perimeter Plus Vehicle Security System, a shock and impact sensor module. After a simple plug-and-play installation, the module automatically activates with an ignition cycle. Dealer programming is only needed if you want to add the optional remote start feature." So ill just sit here on the patio, feed the squirrels and hummers, drink my martunies and think happy thoughts. Let us know if you decide to go ahead and put one in. 1 Quote Link to comment Share on other sites More sharing options...
Hollywood1 Posted October 3, 2025 Author Report Share Posted October 3, 2025 My dealer told me the same thing that the shock sensor is plug & play. The issue I'm having is that the install directions I'm finding online for 18-22 ask you to plug it into a BCM under the dash to the right of the column and my 24 doesn't have a module there. Now I need a tech with access to the new Ford schematic and installation manual to tell me where this thing plugs into. The accessory catalog shows I have the right part and it's made for my 24. Help? 1 Quote Link to comment Share on other sites More sharing options...
Hollywood1 Posted October 28, 2025 Author Report Share Posted October 28, 2025 To the top for an answer to my question Quote Link to comment Share on other sites More sharing options...
