ArkansasEdge Posted January 20 Report Share Posted January 20 I use a cargo liner and the side blocks the OEM cargo light, so installed an LED strip. This is the one I bought, but the listing doesn’t show white as an option currently. Sandfren Car Trunk LED Strip... https://www.amazon.com/dp/B0F9T51GVT?ref=ppx_pop_mob_ap_share Made a significant difference! 3 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted January 21 Report Share Posted January 21 I assume you tapped into the factory cargo light wiring harness for power??? 2 Quote Link to comment Share on other sites More sharing options...
ArkansasEdge Posted January 22 Author Report Share Posted January 22 Yes, I tapped the factory cargo light. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted Saturday at 04:10 AM Report Share Posted Saturday at 04:10 AM (edited) How to disable the standard trunk light? Is there a fuse? Edited Saturday at 11:48 AM by Iroga Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted 14 hours ago Report Share Posted 14 hours ago I would pull the light out and disconnect the power. Probably a good idea to secure the loose wiring somewhere. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted 5 hours ago Report Share Posted 5 hours ago On 1/30/2026 at 11:10 PM, Iroga said: How to disable the standard trunk light? Is there a fuse? The storage pocket above the cargo light is pretty easy to pull and gives you access to the light's plug. Quote Link to comment Share on other sites More sharing options...
