jbrumley1 Posted February 13 Report Share Posted February 13 Just ordered a Turbosmart 1.5/twin scroll 2.7 Kompact EM BOV VR2 50/50 to replace the stock BPV. Anyone have a 50/50 BOV you can comment on, so far as where you noticed a difference other than the 'PSSSH' sound factor? Maybe less lag on initial acceleration, better throttle response between shifts, smoother power over the power band? I'd much appreciate your comments. 1 Quote Link to comment Share on other sites More sharing options...
Oldandintheway Posted February 13 Report Share Posted February 13 Ugh, this is the curse of the "car guy" mentality, of which I suffer greatly, I modify all my cars because I can. No performance gains other than noise. Which is ok as long as your expectations are in line. 2 Quote Link to comment Share on other sites More sharing options...
jbrumley1 Posted February 13 Author Report Share Posted February 13 Hoping it helps later-down-the-road. Just doing basic pre-mods before upgrading the turbos. I've only done NGK colder plugs, Livernois tune and painted my calipers 'Ford Blue'. Next will be catted downpipes and CVF Performance FMIS intercooler. Afterward, will be upgrading fuel pump and injectors. Only looking for about 400 AWD HP and 420 AWD TQ with a dyno tune to up the boost a bit. That's why I ordered the 50/50 BOV to take some stress off the current turbos on long trips. Hey, thank you for responding. What do you think about my upgrade plan? 1 Quote Link to comment Share on other sites More sharing options...
Oldandintheway Posted February 14 Report Share Posted February 14 Your plan is solid! Should be a blast once you have it all dialed in. My wife drives our Edge ST mostly, so I want to try and not go too nuts with it. So far just the Unleashed 93 tune and one step colder Ruetheniums and a custom air intake crafted by @Xtra that I acquired from a past member. The intake is sweet, adds a nice growl too! I have colder thermostats on hand and will most likely do the CVF FMIC this summer. Almost forgot, it sits on H&R springs (bought it used and already had them) I am tempted to try another tune, I saw one that keeps the OAR learning like the Monster Adapt-X I have on my Focus ST. Quote Link to comment Share on other sites More sharing options...
jbrumley1 Posted February 14 Author Report Share Posted February 14 Thanks, Oldandintheway. I'm 68, so, I feel your pain ... ha!! I'll probably just do a K&N drop-in filter for the air intake to squeeze a few ponies out of the factory intake for now. CAI later down the road. Don't want to go too far with the upgrades. Just a fun daily driver is what I'm looking at. Think I should do the pedal thing-a-ma-jig? I've read they improve throttle response a lot. Any downsides to them? Quote Link to comment Share on other sites More sharing options...
jbrumley1 Posted February 16 Author Report Share Posted February 16 Justb received and installed the Turbosmart 1.5/twin scroll 2.7 Kompact EM BOV VR2 50/50 to replace the stock BPV. It feels a little different as 50% of the pressure is released and the other 50% recycles back through to hold turbo pressure, which feels smoother and the shifts seem to be a little more consistent. I'm overall content with it, but, not overly joyed. Anyone else have this same 50/50 BOV? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted February 19 Report Share Posted February 19 (edited) On 2/13/2026 at 5:45 PM, jbrumley1 said: Hoping it helps later-down-the-road. Just doing basic pre-mods before upgrading the turbos. I've only done NGK colder plugs, Livernois tune and painted my calipers 'Ford Blue'. Next will be catted downpipes and CVF Performance FMIS intercooler. Afterward, will be upgrading fuel pump and injectors. Only looking for about 400 AWD HP and 420 AWD TQ with a dyno tune to up the boost a bit. That's why I ordered the 50/50 BOV to take some stress off the current turbos on long trips. Hey, thank you for responding. What do you think about my upgrade plan? It's your money so spend it any way you wish, however . . . The BOV will gain you that whoosh noise you want, but that's all. If you are looking for 400 / 420, then an Unleashed Tune will get you there. Average numbers are gains of 60 HP / 70 TQ. I have no idea what the Livernois tune got you as you have not said. An FMIC is a good addition as it will help keep a cooler charge, not more power. High flow CATS? If you think those are going to get you big power gains, they won't. But, they could change your exhaust noise, given a larger exhaust. Bigger turbos? You won't need those either to reach your stated goals ( 400 AWD HP and 420 AWD TQ ) Edited February 19 by Samurai Edge 2 Quote Link to comment Share on other sites More sharing options...
Oldandintheway Posted February 19 Report Share Posted February 19 I will second Unleashed Tuning, Torrie is very helpful and knows his stuff. I only mentioned the octane learning because it would be great since it is primarily my wife's DD, but she knows to run nothing less than 93, and if not available I can walk her through flashing the 89 tune. As for the pedal question: On 2/14/2026 at 3:57 PM, jbrumley1 said: pedal thing-a-ma-jig if you are referencing the "Pedal Commander" or similar OBD plug in devices, hard pass on that. I would not recommend. Any tuner (Unleashed, Livernois) will be the way to go using a proper SCT, BDX etc tuning device is really the only way to go. Unleashed will upgrade the transmission shifting which is a HUGE improvement on it's own. I wouldn't mess with the cats, unless you are racing and need every bit of edge (pun intended), but that would go with big turbo's , full exhaust and fuel system upgrades to say the least. Quote Link to comment Share on other sites More sharing options...
jbrumley1 Posted Friday at 10:29 PM Author Report Share Posted Friday at 10:29 PM (edited) I'll have a local guy, Jake LaMotta, do a custom dyno tune on it, once I get the parts on. Minor upgrades were already installed. NGK colder Spark plugs, TurboSmart 50%/50% BOV (keeps pressure on the turbos between shifts - only 50% vents to atmosphere so the turbos don't have to work so hard), 170* Reisch thermostat (installation this week), aFe Max Flow Dry drop-in filter installed, and CVF FMIC (Installing in April or May}, are all mainly for Florida summer heat not for power so much. Trying to keep the stock exhaust as close to stock as possible ... sleeper ... quiet and fast. Just got around to installing the aFe air filter and I can tell a couple improvements. Seems like it was starving for air through the paper filter. 1. Dead stop launch doesn't lag quite as much. 2. Feels like it pulls and keeps pulling a little harder in each gear, as compared to before. Edited Sunday at 08:56 PM by jbrumley1 Installed new stock air box filter 1 Quote Link to comment Share on other sites More sharing options...
Jgwentworth Posted 17 hours ago Report Share Posted 17 hours ago Can you set boost psi with the unleashed tune? Or is that manually with the waste gate? can active grill shutters be completely disabled and removed? anyone run the 91 tune, is it noticeable in acceleration? Lastly what happens in sport mode with tunes, does it just change shift points and run at higher rpm? Quote Link to comment Share on other sites More sharing options...
