enigma-2 Posted March 6 Report Share Posted March 6 The radio FM circuits work above FM quieting, resulting in no static. If you're getting static, its either durme to a very weak FM signal being transmitted (<60db) or poorly built cables inducing static from a loose connection. (My money is on the transmitter.( Try tuning mid FM band. As for losing disk 4 and 5, I'd suspect that they were copied incorrectly. Sync 4 is an excellent system. Quote Link to comment Share on other sites More sharing options...
niceonept Posted March 6 Report Share Posted March 6 On 3/3/2026 at 2:56 PM, Ronno6 said: As an experiment, I connected my MP3 player to the audio system via USB from MP3 player to USB input of the Edge. The result was the same as with the flash drive. It played tracks 1,2,3m then jumped over 4 and went to 5. Obviously there is something amiss with the ID tags. I didn't check to see if ie would play all the discs or not...........that point be moot. I believe that the MP3 player will play all the tracks and discs in order, so I'll connect the audio out to USB when my cable arrives today. This will be the last gasp attempt for using MP3...except for the FM adapter... I don't know what MP3 player you are using but I have six Apple iPod Nanos and an iPod touch in my car and all play albums and playlists in the correct order. Sync also allows you to over-ride it and shuffle them, if that's what you want. Maybe the problem is the version of Sync you have? I have Sync 3 in my 2018 Edge which works ok with iPod Nanos and Touches but not with the iPod Classic, which worked fine with Sync 2 in my Ford Mondeo, so maybe Fords are abandoning support altogether? Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 6 Author Report Share Posted March 6 Hi, Pete, I have tried a Sansa Clip+, another cheap player from Azamon, and a 2 different flash drives. When connected to the USB port, they all mis-played the same. However, both MP3 players will play tracks and discs properly thru headphones. The SYNC4 would start playing without any command, and all devices would begin playing the same audio book, even tho it is way down on the list. I'm sure that the main problem resides with the ID tags. I do not know how to manage those. When I attempted to move books from my PC to itunes, the 5 disc book only transferred the first 3 discs.. Maybe I can rip the CD's to itunes, then copy to my iphone........ Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 6 Author Report Share Posted March 6 I wonder......... Mr Pete may have given me a clue... Would an Ipod nano or other model play using the AppleCarPlay in the SNC4? I copied a disc to itunes, then downloaded onto a flash drive....same problems play 1,2,3. jump to 5, then play 5,6,7, skip 8...... I can sync that to my iphone and see if that works.... Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 6 Author Report Share Posted March 6 AHA !! I have identified 1 anomaly with playing the MP3 tracks. The audio book in question has 5 discs............disc 1,2,and 3 have author name and book title. Discs 4 and 5 are listed as "Unknown Artist" That screws things up alphabetically....... Even tho I had named the individual discs, I did not rename the tracks...... I am ripping to Apple itunes in an effort to copy to my iphone. The itunes lists the author and book name for disc 4, and 5 Maybe it is grabbing the metadata automatically?? Hoping that'll work.......... Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 6 Author Report Share Posted March 6 (edited) Looks like the FM Modulator thingy is gonna be the ticket. Once I backed out of the garage the static abated greatly. 87.9 is a clear frequency country-wide. As long as there aren't stations on 88.1 it shouldn't see any interference. The modulator only has about 2hrs run time, so I need to get a suitable power cord. I would prefer to plug it in at the power-only ports at the rear of the console, which I believe are USB-C and the FM unit is mini-USB..........geeeeeeeeeezzzzzzz..... Apparently loading the discs onto the iphone requires Apple Music, another $11.00/month....... no, thank you... Edited March 6 by Ronno6 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 7 Report Share Posted March 7 (edited) 🙃👎 . Edited March 7 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 7 Author Report Share Posted March 7 All this would be unnecessary if there is a CD player that interface with the Edge SYNC 4 hardware..... I tried one initially, but the Edge would not recognize it......... Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 7 Report Share Posted March 7 (edited) These CD players will plug into a Ford Sync-4 USB data port and allow control of the music through the steering wheel buttons. https://share.google/JOUVRO9schVqQ83QI https://share.google/AUDZbBsW9GuaHvLTa https://share.google/bQStB1tuNWteplWQJ After you plug it in, tap "Audio" on the Sync 4 screen, select "Sources" and choose the "USB" to begin playback. Allow approximately 30 seconds for the system to index the CD before trying to navigate tracks. Finally, make certain that you plug the player into a USB port which is not power only. (Certain USB ports in your Sync 4 are power only and do not support a data connection. Owners manual will show which. Believe that they have special markings to tell you power only.) . Edited March 7 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 7 Author Report Share Posted March 7 (edited) Thank you. Only the 3rd link would come up. The other 2 gave me the following: The page isn’t redirecting properly Firefox has detected that the server is redirecting the request for this address in a way that will never complete. This problem can sometimes be caused by disabling or refusing to accept cookies. I was unable to open in Google Chrome also... Edited March 7 by Ronno6 Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 7 Author Report Share Posted March 7 At the risk of speaking too soon........... Itunes seems to be doing the job of ripping the CD's and moving to a USB thumb drive. Tracks and discs are playing in order... The acid test is being copied now... a book w/10 discs. Hopefully, disc 10 will not play immediately after disc 1... I believe itunes is labeling them 01, 02 etc....... Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 7 Author Report Share Posted March 7 I have ripped and copied 2 AB to a flash drive, with different results. The first book has 5 discs, and they all went into the same folder. I can start at D-01 T-01 and play continuously thru to the last track on the last disc. Dunno haw I did that. It is kinda nice... The second one copied each disc to a separate folder..... That one will play all the way thru Disc 1, but not move on to disc 2 automatically........ Sometimes, If I play the last track on a disc, and open the Edge menu and tap "Play All" it will move onto the next disc. Most times, it cycles back to the first AB, D-10, T-01....... I have a difficult time dealing with inconsistency... I guess I will just have to advance to the next disc manually.... Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted March 16 Author Report Share Posted March 16 (edited) Maybe I am on to something...... I read that SYNC 1 & 2 use the FAT32 filing system on USB, whereas SYNC 3 & 4 use exFAT.............. Would that make a difference in the way files formatted in FAT32 are organized and read by the SYNC 3 & 4 systems?? Edited March 16 by Ronno6 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 16 Report Share Posted March 16 In Sync 3 & 4, I believe that the partitions should be set to "Master Boot Record" rather than GPT. (exFAT works better for drivers >4gigs.) Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted Sunday at 04:51 PM Author Report Share Posted Sunday at 04:51 PM The ultimate solution came in ripping each CD as 1 track using a ripping program. Fill in ONLY Title and Artist and disc #/sequence ala 1/5; 3/5 etc. Rip in Windows 11 to: Music\Audiobooks\ A file name for the Author will be automatically assigned. After ripping, go to an MP3Tag editor and give each disc a name of your choosing, Title and Author. That's all that is really needed, until you add multiple books by the same author. I set up a separate file for each book in the author folder.... For books that I downloaded using Windows Media Player, I import each CD's tracks into Audacity, combine the tracks into 1, then export to the Audiobooks folder. Edit the MP3 tags for each disc with Disc Name, Title and Author. Delete any other info. The initial playback issues arose due to inconsistent metadata/MP3 tagging. This information is user contributed, and seems that no 2 users use the same, consistent format. For example, one will say "Vile, Impregnated Salt Tablets;" another will say" Impregnated Salt Tablets, Vial," you get the drift. If the track information did not match EXACTLY to every other one, including spaces, dashes, capitalization, etc, the tracks will NOT play in order in the SYNC system............. Quote Link to comment Share on other sites More sharing options...
Ronno6 Posted Monday at 12:16 PM Author Report Share Posted Monday at 12:16 PM I guess the SYNC 4 system is NOT an MP3 player. More of a data reader?? Files that would play perfectly in an MP3 player would NOT play properly if there existed ANY inconsistency in file names/tags, etc. As an example, if a track is missing a capital letter in its name that is present in all other tracks, it will not play in order.... If a track is missing a 0 in front of the track #, it will not play in sequence....... Really makes setting up audiobook files way too tedious.... Combining all tracks on a CD into 1 really simplifies the process. As long as the flash drive remains plugged in to the slot between drives, the SYNC will remember the stopping point, and resume there when accessed again........ A bit of a learning curve.......... Quote Link to comment Share on other sites More sharing options...
