lalondem_98 Posted yesterday at 04:13 AM Report Share Posted yesterday at 04:13 AM Edge SE 2010. Just before the water pump failed there was a moment where the engine sounded like no oil was circulated so when I replaced the water pump and timing chains and also replaced the oil pump (Melling M390, rockauto). I understand that it is very possible that the oil-not-circulated noise was due to coolant in the oil but at 230000Km and "being there" for repairs it made sense to change it anyways. When I finished the repairs I wanted to prime the oil pump and crank the engine without having it started by using the fuel shutoff switch however it was too painful to disconnect it and I was eager to start the engine so I forgot about priming, turn the key and it started right away and a huge smile was seen! Here is my first question: is it possible to have air trapped somewhere? either in the pump or the passages? I drove the car around many times so it if could eliminate by itself it is done by now. Nervous about the oil pressure I installed an aftermarket oil pressure gauge (2 in. LED Oil Pressure Gauge) but I had to do some plumbing with a 1/4 male NPT bar or block with a 1/4 female NPT and a 1/8 female NPT; the ford oil pressure sensor is connected at the end of the bar or block in the 1/4 FNPT, a 9 inches high pressure hose is connected in the 1/8 FNPT and at the end the Titan sensor is connected. See the 2 pictures. Remember the smile above? Well there was none this time when I started the car....the oil pressure light in the dash is constantly lit and the gauge reads 0 psi; the engine is running fine but noisier than usual...giving the impression oil is lacking. I get it that my custom setup is making both sensors to report no pressure. Anyone ever installed an aftermarket oil gauge? I also forgot to mention that the initial Ford oil pressure sensor failed and flooded the area around the alternator , and the alternator itself too and the engine stalled... I could not restart it until the next morning once the oil has dripped out. Quote Link to comment Share on other sites More sharing options...
lalondem_98 Posted 10 hours ago Author Report Share Posted 10 hours ago Just a brief update that the oil pressure gauge has started giving readings...maybe it needed to have oil accumulated in the t connector block and the flexible hose of 9 inches. Pressure is low at an average of 20 psi. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 2 hours ago Report Share Posted 2 hours ago With a new oil pump and the pressure remaining low it points to bearing issues - if you intend keeping it then it may be time to start looking at replacement engine, rebuilt exchange engines is an option. Quote Link to comment Share on other sites More sharing options...
lalondem_98 Posted 15 minutes ago Author Report Share Posted 15 minutes ago thanks for your reply. I will keep it until it dies in its present condition! Seriously, I will try putting 5W-30 instead of 5W-20, remove my plumbing setup and keep the original oil pressure sensor screwed into the block. I started to get OBD codes P0022 and P0012 which means camshaft over-retarded and could be caused by low oil pressure at the VCTs. If ever the engine is ruined it means it did not survive to almost all of the coolant mixed with the engine oil due to the water pump. Prior to the water pump failure the engine was running fine. Quote Link to comment Share on other sites More sharing options...
