dabangsta Posted August 17 Report Share Posted August 17 Something seemed off last trip. My giant cup no longer required being pushed into the cup holder, and it wobbled. Come to find out the bottom on the front of was sagging, the fingers pushed out, and the rear one was lose and the rubber bottom had the tab out of reach between the pieces. Driving through dust storms and living in the desert these piano black panels are terrible looking in a day. So after pulling out the side trim of the center console, pulling up on the center console at the rear and front, and disconnecting the auto Stop/Start button, removed the cup holder section from the console. The sonic welded spots had all broken. elastic/silicone/rubber band that provides the resistance for the fingers that grip your cup(s) I just used a 2 part epoxy after roughing up the surfaces. I have the feeling I will be doing this again soon, I am going to get POM rivets for that now that I see what I am up against. Yes, I forgot to install the band before putting the bottom back on, so I had to get creative with it. These are $25 from online Ford dealers, so if I screw up too bad next time I will just buy a new one. But the posts and welds are pretty bad. 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 17 Author Report Share Posted September 17 Apparently my family are aggressive cup holder users. The epoxy and other adhesives didn't work out, shocker, I know. I was going to get the POM plastic pop rivets and tool, but I figured I would try a 1/8 aluminum with a backing on both sides. I think this is the winner. I have a plastic welding kit I will do the 2 that don't have an open backside, but I won't be doing it again, I will order another cup holder. The gore: I found a decent length one, I have quite a few mismatched collections of rivets. I would have liked a little longer body, but these snapped the mandrel before enough pressure to break the plastic, and with the backers, shouldn't pull through. 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 28 Author Report Share Posted September 28 I forgot to add I tried the clips that are used by Ford to fix this issue with the 2020-2024 Explorer (I grabbed a handful of them from the you pull it junk yard, same as used for most Ford cowl covers) but unlike the Explorer, there is not a large enough flat spot to use the clips. 25-2614.pdf 1 Quote Link to comment Share on other sites More sharing options...
