PTU and Rear Diff Fluid?
bruker
Just changed the rear diff fluid. It's a piece of cake. The fill plug's in a tight spot but a wobble socket extension made easy work of it.
Went up front and checked to see if there's drain plug on the PTU and there is, just as shown in the YT video. I bought the vehicle when it had 28K on it three years ago so I'm not sure if it's already been replaced.
Well, at least you have a drain plug so that helps.  It's the fill plug that will get you now.  It's a tight spot so you will need a vacuum pump to get the fluid in there.
Just a note:  If you do a good enough search, you will find a YT video where someone shows how they installed their own PTU drain plug.
