Mike12086 Posted October 29 Report Share Posted October 29 Had my Edge overheat today. Found Blown cooling fan fuses and a seized cooling fan on the drivers side. Looking at the procedure for replacement seems to require disconnecting the A/C system and removing everything as a unit (Ford calls it a cooling module). Has anyone done a replacement and is it possible to either slide just the fan shroud out the top or bottom without removing everything? Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 29 Report Share Posted October 29 (edited) Check this thread and let us know if your Sport is the same. Cooling Module 2.7L.pdf Cooling Fan Motor and Shroud 2.7L.pdf Edited October 29 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
