marekrbk Posted November 1 Report Share Posted November 1 I'm trying to get the IACC—Intelligent Adaptive Cruise Control For it to work, the requirements are an IMPA KT4T-19H406-C* The version starting before the last character must be c, the last one is irrelevant. and CCM module from 2020 or later, plus the necessary configuration. For proper operation, it is necessary to make a hardware change, as I described in the "lane centring" section. so, by replacing the CCM and IMPA modules and modifying their wiring IPMA,IPC,APIM It will be necessary to configure this hardware. I will add further findings. 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted November 5 Report Share Posted November 5 Nice Quote Link to comment Share on other sites More sharing options...
marekrbk Posted Sunday at 04:04 PM Author Report Share Posted Sunday at 04:04 PM (edited) So, I was looking into the feature today; I have everything required enabled, but I still can't turn the function on. In the image, I’m using this specific configuration for the Lane Centering feature. If I change the settings, the system throws an error and the collision warning/prevention stops working. Essentially, to get IACC (Intelligent Adaptive Cruise Control) working properly, the ABS pump would need to be replaced with one from a facelift model—but there is a hardware compatibility issue there. It looks like the ABS pump needs to be replaced; the only issue I see is with the coding, as the software in the ABS unit does not include the PowerShift transmission. J1GC-2B373-EC Edited Sunday at 08:42 PM by marekrbk 1 Quote Link to comment Share on other sites More sharing options...
