Don Mulvey Posted 2 hours ago Report Share Posted 2 hours ago Did not want to hijack a similar thread ... same topic but different model year Edge. I have a 2015 SEL3.5L FWD. Replacing pads with OEM. Fronts fit fine. Rears are way too thick. The caliper won't fit over them. Pads are too thick. I ... - put rear brakes in service mode - used a rear brake piston compression tool for electric parking brakes ... worked perfect ... piston is left hand threaded BTW - bought Motorcraft BRF-1474 pads - verified fitment with the online Ford parts store - bought hardware kit too I just looked online and a different online store says to use part DG92-2200 Anybody know what the correct pads might be for this 2015 ? Getting tired of pulling it apart only to find a problem in stalling new pads. Thanks! Quote Link to comment Share on other sites More sharing options...
dabangsta Posted 51 minutes ago Report Share Posted 51 minutes ago BRF1474 is the same as DG9Z2200F. Did you put in your VIN in the FordParts site, or just manually enter in your vehicle specs? There is a part year (maybe earlier than 1/19/2015 build date) change that maybe they are different. I had to compress my rear pistons again after a couple of minutes because they started popping out before I could get it assembled. How flush is it after you have compressed them? Did you also replace the rotors? A ridge on old rotors might make it harder than the full thickness of new rotors. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted 36 minutes ago Report Share Posted 36 minutes ago Do your existing pads have a spring at the top of the inboard pad and a large spring on the outside of the caliper: Or does it have stainless rattle and glides that go on the end of the pads on the ears? Quote Link to comment Share on other sites More sharing options...
