oskar27 Posted 11 hours ago Report Share Posted 11 hours ago I have a 2016 Edge Titanium 2.0L EcoBoost with 65K Kilometers, never had any problems and I love my car (it's my second Edge, my first was 2013 Edge Ltd). I know about the water cooling into the cylinders problem but so far so good. Recently when I start the engine from cold I keep hearing for a few seconds something like the timing chain is loose. Today I went to the dealer for oil change and asked to check the timing chain and I was told it is loose but it can wait. So I said lets order the parts and we will decide when to replace the chain. Searching it looks like a complicated work and my question is: Should I change it now or wait? Many thanks Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 3 hours ago Report Share Posted 3 hours ago If your timing chain is loose, then that is not good. If the timing chain is loose, then it can slip a gear tooth, or more. What happens then, at the least, you could damage one or more valves, at a minimum. Then you are looking at a valve job ( expensive ) or worse. Can't always tell exactly what happens because every case is different. I have heard of a couple of valves being damaged, and of a head being ruined. So, if it was me, then I would have it fixed right away. Yes, it is a complicated job. The main important issue is lining up the timing marks correctly and ensuring they don't move while you are tightening everything down. It can be a DIY job BUT if it is done wrong, you can do a lot more damage. KNOW YOUR LIMITS! Quote Link to comment Share on other sites More sharing options...
oskar27 Posted 2 hours ago Author Report Share Posted 2 hours ago I understand and thanks for the reply. The place I service my car its a large Ford dealer and although this may mean nothing I hope they have good mechanics. So far I have been very happy with them. Also when we say "loose" it depends how much. The dealer didn't say it must be done soon as possible, I said when the parts arrive call me to make an appointment. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 1 hour ago Report Share Posted 1 hour ago The problem is you don't know how loose it is, and the mechanic can't either unless he removed the timing chain cover to check the chain tension. You only have about 40,000 miles US on your vehicle. Timing chain replacement intervals are typically about 100,000 miles US or about 161,000 KM. So, it seems fairly early to need a timing chain. Ford says " Lifetime " on the timing chain, ie; it never needs to be replaced but I never believe in these lifetime guarantees. Typically dealerships, which means the manufacturers, consider " Lifetime " to be to the end of the vehicle warrantee you get when you purchase the car. And there is more than just the timing chain. When you are in there, there are tensioners, pulleys, water pump that should also be changed because if they are not replaced, and they fail later, you will pretty much be spending the same money all over again so better to spend some more now than a lot more later. You can read this to get a better idea of the timing chain on Fords. https://hoodandengine.com/ford-edge-timing-chain-replacement Quote Link to comment Share on other sites More sharing options...
