mark abby Posted September 24, 2009 Report Share Posted September 24, 2009 the bottom plastic door moldings on our 2007 Edge keep popping out near the door edge. i can slap them back in place, but eventually they pop out again. is there any way to fix this once and for all? it's kinda embarrassing when the things stick out like that. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 25, 2009 Report Share Posted September 25, 2009 warranty with dealer? OR, I would likely just use silicon adhesive on them. the great thing there is it should hold them and not damage the car and always can be easily removed and create water proof seal all at the same time. silicon is an awesome adhesive. Quote Link to comment Share on other sites More sharing options...
ablb Posted September 25, 2009 Report Share Posted September 25, 2009 the bottom plastic door moldings on our 2007 Edge keep popping out near the door edge. i can slap them back in place, but eventually they pop out again. is there any way to fix this once and for all? it's kinda embarrassing when the things stick out like that. We (learned to ) open the door a little wider when we (I) get out. ab Quote Link to comment Share on other sites More sharing options...
07CRUSH Posted September 26, 2009 Report Share Posted September 26, 2009 check the clips on the back of the moulding, you might have a bent clip Quote Link to comment Share on other sites More sharing options...
mark abby Posted September 27, 2009 Author Report Share Posted September 27, 2009 warranty with dealer? OR, I would likely just use silicon adhesive on them. the great thing there is it should hold them and not damage the car and always can be easily removed and create water proof seal all at the same time. silicon is an awesome adhesive. yep. i used DOW clear RTV sealant. it worked perfectly!!! Quote Link to comment Share on other sites More sharing options...
