o8 edge ptu
hovy
Going in today for repair #5 on my 08 SEL. Redesigned seals put in on repairs 1 &2, new PTU put in on repair #3, axle & seal replaced repair #4. Don't know what is next. I refuse to drive it in when it is leaking so as to avoid further damage to the transmission - the fluid is usually down at least 1 qt. If you have roadside (under warrantee) I'd recommend using it. just my $0.02.
You have got to be kidding. 5 times? Sounds like they need to replace more than the seals.
  • 4 weeks later...
the smell is back!!! its been 3 months since i had the seal replaced..
i took it to the dealer and they say there is no leak, i can only recreate the smell after driving for 20+ minutes and coming to a stop, how can i show this to the dealer, if its intermittient, and they have some tech with no sense of smell!!
any suggestions?
it smells like rotten eggs, or some foul farts...
any suggestions?
Are you sure it's not the car beside you? I was very sensitive to the smell as well but some time it was not me. Every time there is change of smell I would freak out. But when I took my Edge to the dealer they could not find anything.
