strokersix Posted January 17, 2010 Report Share Posted January 17, 2010 Wanted to check and see if anyone knows what this drain tube is............. It is on the drivers side next to the gas pedal right on the side of the "tranny hump", looks to be about a 3/4" diameter hose coming from behind the console and looks like it should drain to the exterier. There is a hole right there and open but the hose just hangs with no fitting. We've had our '10 edge limited w/panoramic roof about 1 1/2 months and my wife was vacuming the inside out and noticed the carpet and pad were just soaked...... so much for trying to keep the carpet nice and dry with the weather-tech matts. -Thanks guys and gals for any help. Quote Link to comment Share on other sites More sharing options...
07CRUSH Posted January 18, 2010 Report Share Posted January 18, 2010 Wanted to check and see if anyone knows what this drain tube is............. It is on the drivers side next to the gas pedal right on the side of the "tranny hump", looks to be about a 3/4" diameter hose coming from behind the console and looks like it should drain to the exterier. There is a hole right there and open but the hose just hangs with no fitting. We've had our '10 edge limited w/panoramic roof about 1 1/2 months and my wife was vacuming the inside out and noticed the carpet and pad were just soaked...... so much for trying to keep the carpet nice and dry with the weather-tech matts. -Thanks guys and gals for any help. That is the drain tube for the AC.Hope that helps u :hyper: Quote Link to comment Share on other sites More sharing options...
strokersix Posted January 20, 2010 Author Report Share Posted January 20, 2010 That is the drain tube for the AC.Hope that helps u :hyper: Thanks 07CRUSH, that is exactly what it was. the factory forgot to install the nozzle assy so all the moisture and water drainage went right to the carpet, not to the exterior of the vehicle where it should have gone. Also while it's at the dealer they are replacing the keypad on the outside of the door, 2 lights already burned out...... and a little over a month old. Quote Link to comment Share on other sites More sharing options...
Matts 2010 Edge Posted January 24, 2010 Report Share Posted January 24, 2010 That is the drain tube for the AC.Hope that helps u :hyper: Dang beat me to it! Matthew Quote Link to comment Share on other sites More sharing options...
