2008 AWD LTD: Reverse lights are too dim
Hi All -
New Edge owner here. Just purchased a 2008 AWD LTD last week. I was at a friend's house the other night on a very dark street. When I got into my Edge and put it in reverse, I could hardly see at all as I was reversing. The reverse lights seem to work but are not illuminating that well when in reverse on a dark night. I did the same thing last night with my wife so she could see the problem.
Has anyone else experienced this issue? Possible solutions?
Thanks.
  • 3 months later...
:reading:
I had a problem with my '06 Explorer Limited with rear turn signal bulbs not always working. Took it to the dealer,they had to replace the rear wiring harness. When they found the problem, they said that the backup lights were also very dim ! Your problem might be related, I don't know.
Joe
Edited by JOEHIO
If they're coming on at all - then it's a bulb issue. I'd replace them with an LED bulb because those are always super bright and come in all shapes and sizes. Some guys on my Lotus forums use this site: http://superbrightleds.com
I believe these are the bulb sizes for the 08 Edge
Low Beam Headlight Bulb Size: H11
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157NALL
Front Turn Signal Light Bulb Size: 3157NALL
Rear Turn Signal Light Bulb Size: 4157LL
Tail Light Bulb Size: 4157LL
Stop Light Bulb Size: 4157LL
High Mount Stop Light Bulb Size: LED
Fog/Driving Light Bulb Size: H11
License Plate Light Bulb Size: 6418
Back Up Light Bulb Size: 921
Rear Side Marker Light Bulb Size: 194
Map Light Bulb Size: 2825 or 3886X
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 2825 or 37
You'd need a new 921 size bulb but I'd pull the old one out first and read what it says on it to be sure that's the right size.
Halfway down this page: http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html
they're about $5.95 a piece in Cool White or Natural White
