Low Exhaust?
I picked up my new 2011 FWD Edge last week.
The exhaust seems low in the middle. I see why the front end is where it is, but it drops down after the first muffler and stays that level until it turns up the reach the rear mufflers. It is 3 inches under the body and 2 inches under the rear suspension cross member.
My other cars (Japanese) have had the exhausts tucked up as high as they can.
Is the large space normal for an Edge?
Thanks
Edited by factor99
The might have kept it lower along the length of the car to reduce bends, therefore reducing resistance for tuning purposes. I haven't considered this and would have to look at my car when I have the chance. The exhaust as pictured looks okay, just low.
Are you worried about having it bottom out? The ground clearance is fairly generous which would limit that possibility.
EDIT: Also, just noticed you have a front wheel drive. The additional clearance might be designed to accommodate both FWD and AWD applications, although I might be wrong.
Edited by NatG
