capsfan Posted January 8, 2012 Report Share Posted January 8, 2012 Just bought a 2012 Ford Edge Limited yesterday. Went out to start it this morning using my factory-installed remote start and it won't work. Has anyone else had this problem? If so, how did you fix it -- or did you have to go to the dealer to have them reprogram the remote? Quote Link to comment Share on other sites More sharing options...
seabee78 Posted January 8, 2012 Report Share Posted January 8, 2012 On my 2011 Edge, I have to press the Lock button once and then the Start button twice. Is that same for 2012? Quote Link to comment Share on other sites More sharing options...
Mazz Posted January 8, 2012 Report Share Posted January 8, 2012 On my 2011, I can also turn the remote start function off or on, through the left side steering wheel touch pads. So you may want to delve into that a bit to see if the function is turned off. Quote Link to comment Share on other sites More sharing options...
Scorpio Posted January 8, 2012 Report Share Posted January 8, 2012 On my 2011 Edge, I have to press the Lock button once and then the Start button twice. Is that same for 2012? Same same. On my 2011, I can also turn the remote start function off or on, through the left side steering wheel touch pads. So you may want to delve into that a bit to see if the function is turned off. Good point, it's probably turned off in the vechicle settings. Quote Link to comment Share on other sites More sharing options...
capsfan Posted January 9, 2012 Author Report Share Posted January 9, 2012 Same same. Good point, it's probably turned off in the vechicle settings. we did the push lock button once, then start button twice and it worked. thanks for all the replies Quote Link to comment Share on other sites More sharing options...
mooshin Posted August 15, 2012 Report Share Posted August 15, 2012 I remember having the same problem, THEN... I read the manual and the problem went away. Quote Link to comment Share on other sites More sharing options...
bigman30685 Posted August 25, 2012 Report Share Posted August 25, 2012 I remember having the same problem, THEN... I read the manual and the problem went away. LOL Quote Link to comment Share on other sites More sharing options...
