Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
2016 Edge-Heat affecting A/C, Windows, Air Bag and Center Console
owner issues
  • Please log in to reply
8 replies to this topic
#1 OFFLINE   billc
billc
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Canada Ontario
  • Edge's Year:2016
Posted 07 July 2017 - 04:03 PM
Has anyone had issues with their Edge when heat is above 75 degrees? I have had my Edge in 3 times to correct a system shutdown when the temperature hits 75. The sun is out. As above, the A/C shuts down, front windows don't work, air bags shut off, center console is useless. Not on recall list but just checking with the forum. Thank you.
#2 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 2,971 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2009
Posted 07 July 2017 - 05:39 PM
How old is your battery? (Thinking that the battery is getting low on electrolyte allowing the battety to overheat and drop voltage).
#3 OFFLINE   billc
billc
    New Edge Member
  • Edge Member
  • 3 posts
  • Edge's Year:2016
Posted 07 July 2017 - 07:14 PM
Thank you for the response. The battery reads July 2016. Just doesn't make sense and I (close your ears) sweat easily. Too much time at the dealership and not enough working. Ford Edge Fanatic...any other thoughts that would be obviously be better from the  apparent "pro's"?
#4 ONLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,787 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 08 July 2017 - 05:25 AM
Possible lemon.  Have had other Edges reported with electrical gremlins.  Do you have a lemon law in Canada?
#5 OFFLINE   PaulSchott
PaulSchott
    Ford Edge Member
  • Edge Member
  • 400 posts
  • Edge's Year:2007
Posted 10 July 2017 - 02:03 PM
Your battery may be new but it wouldn't be the first time for something new to be bad.   Can you take a voltage reading when the problem accurse?
Will the car start if you shut it down during the problem?
#6 OFFLINE   billc
billc
    New Edge Member
  • Edge Member
  • 3 posts
  • Edge's Year:2016
Posted 10 July 2017 - 02:27 PM
After my fourth time at the shop they have ordered a new Front Control Interface Module. Will be installed on Thursday. Let's see if it works! Thank you for your help. Glad I'm not paying for it.
  • WWWPerfA_ZN0W likes this
#7 OFFLINE   blockisle9
blockisle9
    New Edge Member
  • Edge Member
  • 235 posts
  • Region:Decline
  • Edge's Year:2017
Posted 30 July 2017 - 05:26 PM
Did it repair the issues?
#8 OFFLINE   Jasroz
Jasroz
    New Edge Member
  • Edge Member
  • 3 posts
  • Edge's Year:2010
Posted 31 July 2017 - 05:58 PM
I have a 2010 with 150k on the engine (I love road trips) and I just recently have been getting overheating issues, hoping its just a blown fuse for the fans or thermostat/gasket issue. I'm surprised to hear its happening on a 2016 though.
#9 ONLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,787 posts
Posted 31 July 2017 - 07:29 PM
If the coolant has never been flushed, Jasroz, ... Though i too am rooting for it to not be a water pump.
  • Jasroz likes this
