Custom Search
Obd code
  • Please log in to reply
6 replies to this topic
#1 Horto
Horto
    New Edge Member
  • Edge Member
  • 2 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2013
Posted 07 August 2017 - 10:24 PM
2013 edge 2.0 eco, engine light on today for 1st time. Scan =P219A ckd dipstick & oil cap. Anyone know if i can drive for a day or 2 to see if it clears. Typical solution? Thanks in advance for any help.
#2 WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,940 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 07 August 2017 - 11:24 PM
Did you have the oil & filter service done recently?  Make sure the dipstick is firmly seated and the oil cap secured.  Then drive it a while and see if it clears.
#3 Horto
Horto
    New Edge Member
  • Edge Member
  • 2 posts
  • Edge's Year:2013
Posted 08 August 2017 - 08:03 AM
Oil serviced @ 1000 mi back. Ckd oil cap & dipstick. Ill watch for a day ir 2. Ok to drive 50-60 mi?
#4 WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,940 posts
Posted 08 August 2017 - 09:11 AM
If you are not smelling or seeing an oil leak, and oil level is between the cross-hatches, yes.
EDIT:  Digging deeper into the code
P219A - Bank 1 Air/Fuel Ratio Imbalance
  • Leaking or contaminated fuel injectors
  • Low fuel pressure or running out of fuel
  • Leaking evaporative emission (EVAP) canister purge valve
  • Exhaust or intake air system leaks
  • Exhaust gas recirculation (EGR) system
  • Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open
  • Ignition system
  • Incorrectly seated engine oil dipstick, tube or oil fill cap
Read more: https://www.autocodes.com/p219a.html
That's a lot of items to rule out ...  Further diagnostics in order if the light does not go out.  Could simply be a bad oxygen sensor, could be an exhaust system/catalytic converter issue, etc.
There is a report on a Subaru Forester that the PCM had moisture penetration, and the pins had to be cleaned & greased to solve the code (no longterm reportback tho).
Toyotas see this code with burnt exhaust valve seats.
Fuel injectors in the case of GMs
https://gm.oemdtc.co...buick#more-3921
Edited by WWWPerfA_ZN0W, 08 August 2017 - 09:24 AM.
#5 enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 3,206 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2009
Posted 08 August 2017 - 01:59 PM
That have a code for not having the dipstick all the way down?
:doh:
Edited by enigma-2, 08 August 2017 - 02:00 PM.
  • WWWPerfA_ZN0W likes this
#6 akirby
akirby
  • Moderator
  • 10,831 posts
Posted 08 August 2017 - 03:07 PM
:doh:
Crankcase pressure I presume......
#7 WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,940 posts
Posted 08 August 2017 - 07:04 PM
Which reminds me, I should check to see if there is a sensor on the cleanside pcv line from the intake to the valve cover. Ford introduced them on SHOs in 2014/15, maybe this engine has one too.
