Custom Search
2018 Edge Tow Package
  • Please log in to reply
7 replies to this topic
#1 OFFLINE   ProudFish78
ProudFish78
    New Edge Member
  • Edge Member
  • 2 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 27 September 2018 - 09:34 PM
Hello,
Does the tow package for 2018 Edge's still include the radiator upgrade and upgraded cooling fans?  Looking through the towing guide and trailer towing selector guide from Ford's site, they are not listed.   Just wanted to verify if they are no longer included or is it a typo on Ford's guides?
2018 RV and Trailer Towing Guide (page 16)
https://www.fleet.fo...de_r8_May15.pdf
2018 Edge Trailer Selector Guide (page 1)
https://www.ford.com...d_Edge_Oct9.pdf
Thank you
#2 OFFLINE   omar302
omar302
    Ford Edge Fanatic
  • Edge Platinum Member
  • 2,069 posts
  • Region:Middle East
  • Edge's Year:2016
Posted 28 September 2018 - 12:35 AM
I'm not sure the 2018 is the same, but for the 2015, fans are the same, but from the service manual it seems for the 3.5L there is an engine oil cooler added while for the 2.0L a transmission oil cooler is added with the tow packages.
Edited by omar302, 28 September 2018 - 12:40 AM.
  • WWWPerfA_ZN0W likes this
#3 OFFLINE   akirby
akirby
    Ford Edge Legal Resident
  • Moderator
  • 11,102 posts
Posted 28 September 2018 - 07:37 AM
I'm not positive but I seem to remember someone saying that those things were now standard on all Edges and therefore no longer part of the separate towing package.
#4 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 3,332 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2009
Posted 28 September 2018 - 05:52 PM
Everything is read matches the responses above. Here's something I pulled off an different site
"Transmission ratio, tranny/engine cooling, brakes and charging systems are all the same with/without trailer tow package. There are no mechanical differences between the two except as follows:
The hitch included with the trailer tow package is an entirely different rear-bumper assembly compared to those without - it is not simply an add-on hitch."
Everything I've also read says that the sway control is installed at the factory and CANNOT be added by the dealer or aftermarket.
Keep in mind that the capacity is limited to 1,500 lbs with factory or aftermarket and no trailer brakes, 2000 lbs with aftermarket and trailer brakes or 3,500 lbs with factory tow pkg and trailer brakes.
Edited by enigma-2, 28 September 2018 - 05:56 PM.
#5 OFFLINE   omar302
omar302
    Ford Edge Fanatic
  • 2,069 posts
  • Edge's Year:2016
Posted 29 September 2018 - 06:32 AM
Attached are the cooling system component locations for the 2.0, 3.5 & 2.7 engines from the 2015 Service Manual. Each one shows the different configuration (Basic, Tow Package and/or Hot market).
#6 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 3,332 posts
  • Edge's Year:2009
Posted 01 October 2018 - 04:55 PM
I *think* akirby was talking about 2017+ models.
#7 OFFLINE   akirby
akirby
  • Moderator
  • 11,102 posts
Posted 02 October 2018 - 08:05 AM
Correct - I think it changed recently.
#8 OFFLINE   ProudFish78
ProudFish78
    New Edge Member
  • Edge Member
  • 2 posts
Posted 03 October 2018 - 11:03 AM
Thanks everyone for the info and clarification.  Good to know that it became standard as opposed to them out right removing it.  Even though it became standard, I wish Ford would have put a note on the fleet guide (actually anywhere really) that stated the change.  I think it would have helped avoided the confusion.
