Everything posted by SweetCandyEdge
2011 Edge 3.5L - Strange Noise when Applying Torque
SweetCandyEdge replied to SweetCandyEdge's topic in 3.5L
Yes I was surprised also. Thankfully it was a relatively simple and cheap fix. -
The issue was a broken flex pipe. -
There is no noise when the transmission is not engaged. There is also no noise when the transmission is engaged but the brake is applied. The noise only appears when the gas pedal is applied and is worse when more gas is applied. -
Hi, My wife's 2011 Ford Edge has started to make a sound when applying the gas pedal while driving. Initially I thought it was an exhaust issue however the sound does not exist if the car is not in gear (ie revving does not produce this sound). The sound only happens when in gear and is much more noticeable when starting for a stop. My wife describes this as the 'race car' sound as it is very noticeable in the car. This does not seem like an engine issue. Could it be transmission, PTU, torque convertor or something else? Any help is appreciated. TIA.
Technique worked great. Thank you for the instructions!
Your new 2016 Edge review
SweetCandyEdge replied to Chipster's topic in 2015+ Edge & MKX Generation II
This is likely the lane departure warning system. You can adjust the vibration intensity or turn the system off if you want. https://owner.ford.com/how-tos/vehicle-features/safety/lane-keeping-system.html -
I would not have guessed that but I'm very happy if that's the case. Thank you very much for the informative link.
I have a 2011 Ford Edge Limited (3.5L AWD) that is dripping a yellow (perhaps lime green?) liquid down the center of the car. The drips appear to be originating around the middle of the vehicle. Any ideas or suggestions regarding what this could be? The colour is similar to the windshield washer fluid but I don't understand how it could be leaking mid vehicle unless the hose for the rear wiper sprayer runs down the middle of the car underneath. I've attached a picture for reference. The drips really show up in the snow. TIA.
Light in USB cubby of 2016 Edge
SweetCandyEdge posted a topic in Interior, A.C., Heat, Interior Trim
How does the light in your USB cubby work? For almost a year I didn't realize there was a light in the cubby until I accidently pressed up on the lid while open... Should the light come on automatically when the lid pops open or do you have to push it up to turn the light on everytime? -
SweetCandyEdge replied to jmr061's topic in Audio, Backup, Navigation & SYNC
I had the "paused" message also. The solution for me was to use a new USB stick. -
Persistence has finally paid off. I tried one more time and voila... it works!!! I did three things differently: 1. I turned off the steering wheel heater on the main screen in the APIM settings with Forscan. 2. I switched the right IPC to audio instead of nav. 3. I purchased a new USB stick. So I reinstalled v1.1 again (thanks to jmr061) and then installed v2.2 from the new USB stick and everything is fine. After a grand total of about 30 installations everything in finally working. -
Thanks so much to jmr061. I was able to reinstall v1.1 and get nav working again. Unfortunately reinstalling v2.2 afterwards ended in the same result with a navigation fault. -
FAT32 MBR -
No luck. ? I tried a few soft reboots and a couple more master resets this morning. The results are the same with a navigation fault. I checked for DTCs with Forscan and there are none. I am going to try the update one more time and then throw in the towel. -
Master reset did not work so I tried another USB stick. Once again, the install succeeded however after turning the Edge off, exiting, and then turning the Edge back on, I am still getting a Navigation Fault. I tried the install another time and it succeeded with Navigation Fault still displayed however I did not restart after exiting. I have left the car to rest overnight... perhaps Navigation will work better in the morning when I restart :S. -
I was at V1. I'll try a master reset. -
I installed the update on my 2016 Edge Sport with nav. The update seemed to go fine however following a restart I received a "Navigation fault" and as a result the built in nav does not work. I've attempted to reapply the update however it fails after about 10 minutes saying "Installation paused. The USB storage device has been changed or removed. Installation will resume when the device is re-inserted.". I tried reinserting the USB and got the same message after about 10 minutes. Any suggestions? I am going to reformat the drive and copy the files again tonight. I verified the hash code and it was correct. -
Sync 3 2016 upgrade to CarPlay
SweetCandyEdge replied to tpm419419's topic in Audio, Backup, Navigation & SYNC
I am very interested in your progress. Please keep us posted ? -
Will it be possible to add Sync Connect to my 2016 Edge? Clearly if it's possible it will cost more than $27 ☺. -
I'd love to have this option available for my 2016. -
I also vote for the DM-V2. I have a set of four on both my 2011 and 2016 Edges and they are excellent winter tires. I also purchased mine at Costco.
