Everything posted by SweetCandyEdge
Answered here: http://www.fordedgeforum.com/topic/19920-edge-sport-vs-titanium-questions/?do=findComment&comment=147780 ☺
Edge sport vs titanium questions
SweetCandyEdge replied to mdy113's topic in Buying, Leasing & Ordering
The Edge Sport is rated at 2000 lbs towing capacity which is Class I. There is a trailer hitch designed for the Edge Sport available from Curt with part number 13234. http://www.curtmfg.com/part/13234 Or from Draw-Tite with part number 75234. http://www.drawtite.com/dt75234.html These hitches are rated as Class III but the Edge Sport is rated as Class I. I believe the Curt fits without trimming the bumper or rear valence but I'm not sure about the Draw-Tite. There are some pictures here: http://www.etrailer.com/question-151937.html A fully loaded Edge Sport will have all of the features of a fully loaded Edge Titanium plus 2.7 L twin turbo engine, sport suspension, different exterior, and different interior. -
I watched and 'liked' the video. About a month ago I put the exact same battery in my 2011 Edge. It's a fantastic battery. My Edge sat outside for two days at -30 Celsius and started without any issue or difficulty cranking
- 2 replies
- 2
- Odyssey Extreme
- AGM Battery
(and 2 more)
037 - 2015 Edge Sport AWD - Photos and Everything else
SweetCandyEdge replied to 037's topic in Owner Impressions
Does it seem like a decent quality? I'm concerned it wouldn't stand up well to winter salt and calcium... -
SEL tail light swap
SweetCandyEdge replied to 67stang's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Here's a tail light bar for sale: http://orlando.craigslist.org/pts/5451274051.html Note that's it's not mine and I cannot vouch for the seller. -
jblahr
SweetCandyEdge replied to Nick Halstead's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Very nice. Mind if I ask where you got it from? -
Your new 2016 Edge review
SweetCandyEdge replied to Chipster's topic in 2015+ Edge & MKX Generation II
Today I confirmed with Jason from fordpimods that his technique for disabling the double horn honk should work on the 2016 Edge. At least he confirmed it for my VIN. Now I just need someone or a local dealer willing to apply the change with Ford IDS. Anyone have access to Ford IDS in Ottawa area? http://www.fordpimods.com/double-horn-honk.html -
Yes it does happen on every start for me however the lock engaging is much more noticeable with remote start since the engine is already running when the lock engages. With regular start the engine cranking, HVAC coming on, radio turning on, etc... makes the lock engaging less noticeable. If you can get the liftgate to stay open (pushing the button should stop it from going down further), I suggest going through the height adjustment procedure since it may correct the issue you're experiencing. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O31263&languageCode=EN&marketCode=US&viewTech=IE&chapterTitleSelected=G1675921&subTitleSelected=G1721975&topicHRef=G1607804&div=f
This is due to the lock engaging on the adaptive steering system. It is normal. There is more info in the owners manual: http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O31263&languageCode=EN&marketCode=US&viewTech=IE&chapterTitleSelected=G1676160&subTitleSelected=G1818245&topicHRef=G1818220&div=f
Aesthetics and performance. Noise from wheels is generally more from the tires due to road noise so a decent set of tires makes a big difference for noise. I find the DM-V2 to be very quiet compared to other winter tires. Larger wheels and tires are generally more expensive and tend to ride more harsh (depending on air pressure) but it's worth it IMO... after all, I did buy the Sport :D. -
Check out the Touren TR60. I've got the gunmetal ones as my winter wheels. IMHO they look good on the Edge and I believe they're available in black.
Updated to recommended . -
20" x 8.5", 40 mm offset, 72.62 mm hub bore Hub centric rings are recommended and I believe the oem lug nuts are a tight fit with the center caps. I went with open ended lugs. -
Yes you should return the Ford 'all weather' mats. Yes the 2015 mats fit the 2016 Edge fine. The Weathertech or Husky Liners are much better. You will likely be disappointed with the Ford ones.
Correct! -
Do you have the original image or the zip file of originals posted by xK317Hx. The Dropbox zip file URL no longer works.
- 2 replies
- MFT
- Touch Screen
I bought the Sport for the extra power and love it every moment I'm on the road. If a bit of extra $ isn't a big deal, go for the Sport and you will not regret it.
Genius lithium battery booster, Schrade telescoping folding shovel, first aid kit, winter toque and gloves, mechanics gloves, duct tape, parachute rope, Gorilla telescoping wrench, bags, rags, reflective heat blanket and a fleece blanket.
Confirmed it's the same on my Edge. One clip at the back had popped off the post and the foam clip was riding on top of the metal post. I repositioned the foam, jammed the clip onto the metal post and now the spare tire cover fits much better. Thanks for the help!
Where are the clips (near front, back or both)? I am pretty sure my 2016 doesn't have clips. Will confirm tonight.
