k1200rsport
Everything posted by k1200rsport
but my f1504x4 is decked....programmer...exhaust, intake, rancho shocks.. camo interior..its nuts! http://www.photoshop.com/users/crstfr/albums/2834682b70b74405adbb570d1ec97f6c check it!..... Instead of adding so many more mods could have just bought a Tundra (5.7) or New RAM.......................................just kidding
Congratulations and welcome to the forum
This is my conversation with Sync rep. regarding 2.8 update. See below. Brian: At this time the 2.8 update is not available as website update. From my understanding the 2.7 is update that required a dealership install. you: ok thanks Brian: The 2.8 update should be available in Early May 2011. you: ok Brian: You may receive a letter from Ford Motor Co. in regards this update. Brian: Is there anything else I can assist you with today? you: Thanks
WHAT???? PROBLEMS WITH MFT????? What are you guys talking about??? My calender and other similar issues are well documented with Ford, because they have responded to me via email and call.
Well, I got the invoice pricing for my Limited, it was $34xxx. But that was the 2nd car in few months I bought from the dealer.
Like I mentioned in the other thread, after the update I had issue with Audio and BT, but I think sync was tresetting itself in the background and after few days it seems to be working better. As far as Clock/ Calender issue it will correct. Dealer also mentioned that they have seen some different issues after 2.7 update.
Well resolved the calender/ time issue but have Audio issue now. When I turn the Audio on, it turns on but no sound nothing, small screen in dash says "Audio off". Turn it ON & OFF nothing. But if I go in the audio screen and select a different medium for example, if AM/FM was playing select Sirrius, everything goes back to normal. SYNC commands are performing OK
Got the update done at the dealer, fixed the calender/ time issue and everything seems to be working the way it should be.
No new model fo atleast till 2014
I just stopped by the dealer and he said that the bulletin they got about Version 2.7 addresses the calender issue, I am taking mine there Monday to get the update done.
Vibrating Passenger seatback
k1200rsport replied to sabasigh's topic in Interior, A.C., Heat, Interior Trim
Well seat does vibrate but I had noise at times and that culprit was seat belt, when I buckled the seat belt (no passenger in seat), the rattling noise went away. -
4 X 8 trailer with a Sportbike sould be fine.
My 2011 Taurus doesn't have this issue, seatback stays steady. -
On 2011 Edge you've to slam th ehood to shut it down.
Which cars you compare the Edge with?
k1200rsport replied to jdf77's topic in Competing Crossovers & Vehicles
I compared Edge to Infiniti EX/ FX35 and Audi Q5 -
I cmplained about the seat back vibration and then the service guy and me checked all Edge's in their lot and they all had similar issue....looks like it is from factory. -
When you rphone disconnects, check the time and date, it should be off too. I've same issue where sync will Reset tiem and dat ean ddisconnect the phone. But on next start it will reconnect itself.
I've 2011 Edge FWD limited, no issues mechanically, but do have issues with MyFordTouch, it resets itself when it feels like and they do not have a solution for it. As far as engine ticking all new vehicles with VVTI make that noise when its little cooler outside and it is only till it warms up, nothing to worry about.
First time to update the Sync, you should have gone under the Apps and install updates. I suggest you take it to the dealer and have them take a look at it instead of you trying to mess with it.
Sirius Travellink Weather tip
k1200rsport replied to viper001's topic in Audio, Backup, Navigation & SYNC
Is sirius travel link only available with Navigation OR is it on all My Ford Touch Systems? -
Media Hub Inputs not working?
k1200rsport replied to mikec's topic in Audio, Backup, Navigation & SYNC
Only issue is 1st time it took a while for it to start playing the music via Ipod -
Also got an email from sync that they know about the issue and are working on it. Keep checking with the dealer to see when the update comes out. But strange thing was after TSB update, I had navigation screens on the sync (I don't have a NAV) and this morning they are gone.
I still have issues with My Ford Touch, where it rests itself and sync suggested a TSB which dealer performed but calender is still off. Sync and dealer said they are working on it. I do not use Iphone for music but no issues with Ipod. Voice recognition 90% is ok.....and I've an accent, so may be my accent.
Dealer just called and said that the update was done but it didn't fix it. They contacted sync and they are aware of this issue and are working on update, the update will be released once they figure out how to resolve it.
SNYC locked up whole screen FROZEN
k1200rsport replied to bmuir40's topic in Audio, Backup, Navigation & SYNC
OR you need the update per TSB 10-24-9
