edgemaster
Everything posted by edgemaster
enigma-2: Are you talking about gasket 5C226?
Thanks for that info. I'll do a check as you suggested, hoping the leak shows itself on a cold muffler system.
Hi Guys, I have a 2009 LTD with about 125k miles, that makes noises lately. The wife says after driving for about half an hour the car gets louder as if the exhaust system was leaking somewhere. So I crawled under to check things. All the rubber hangers look god and are intact. I noticed that small muffler just behind the cat. It is connected to the rear part of the exhaust system with a large clamp and the pipes are stuck one inside another. What's weird is that the smaller pipe is slightly clean for about 1/2" as if those 2 pipes are kind of loose and slip back and forth. Is it possible that, after the exhaust system is sufficiently hot, the 2 pipes get loose and a small exhaust leak develops? Is this a known issue or am I imaginating things?
Thanks for the details, it's very much appreciated. However, I should have phrased my question differently. I was asking for a car wash detergent brand, not a brand of power washer. Sorry, my bad. Ed
Can anyone recommend a good cleaning brand for car wash?
Well, I have used a Kärcher since the late 90s and it lasted about 20 years, so no gas powered pressure washer for me.
Any more input on my question?
The one I was planning to buy has 2000 PSI.
Guys, I have a, probably, silly question: I'm planning to buy a power washer. Never used one on a car and I am wondering if prolonged usage has any negative effect on the exterior (rubber, paint, clear coat, etc.)? I'd appreciate any input pro or contra.
Compass module location and questions
edgemaster replied to ChucklesMcHaHa's topic in Audio, Backup, Navigation & SYNC
There is no box behind the rear view mirror, the compass must be inside the mirror. -
Compass does not work
edgemaster replied to edgemaster's topic in Interior, A.C., Heat, Interior Trim
The mirror? Isn't there a separate compass plug-in or so? -
Hi, the compass in my 2009 Edge has shown only the "N" for several months now. I tried to calibrate it but I can't even set the magnetic zone, it just doesn't show that setting. Does that mean to compass module is broken? If yes, is there any test to make sure? Thanks, Ed
Hi, my 2009 Edge shows the message "Driver Door ajar" and the small red icon in the left of the dash. Of course, the driver door is NOT ajar. Where do I start looking? Thanks.
Haz, thanks for the detailed response. I had ordered the manuals, they are on the way. It appears that the seal is only deteriorating at the front, so just replacing the front part might be possible. Hope that will work.
Just ordered those manuals, thanks for the tip. Thanks again for helping me, looking forward to watching that video.
enigma-2 Thanks for the detailed info. Actually, I'm talking about the rubber seal between the front and the rear glass. I'm not sure which it is on that diagram. And no, that rejuvenator likely won't work, there are large pieces of rubber that can be pulled off.
Perhaps some people have been thrown off by my erroneously calling the sunroof the wrong name (skylights), my bad, sorry. I found a diagram of all the pieces that go into the sunroof but there are so many that I am sort of confused which ones I need to order. I'll attach that image, maybe someone can point me into the right direction? Thanks a lot. Ed
Looks like nobody knows anything about my problem, pity!
Hi, I'm just doing some spring cleaning/detailing on my 2009 Edge LTD and I noticed that the gasket(s) around and between the 2 skylights seems to be disintegrating. Are those 2 separate gaskets or is it one gasket for both? Is there a post somewhere that would describe where to order and how to replace those gaskets? I need to replace them before the Texas Spring storms pop up but have never done it before but and I've no idea how to go at it. Can anyone post some advice/ideas? Thanks, Ed
Power lift gate does not open all the way
edgemaster replied to edgemaster's topic in Exterior & Body
Well, the problem has been solved a while ago by installing new struts. However, those new struts started another annoyance, when the liftgate goes down it rattles to the point that the entire car shakes. -
Wow, everybody on vacation, or what?
Hi, I recently replaced the automatic liftgate struts on my 2009 LTD and now the liftgate rattles every time it goes down, to the extend that the whole car shakes. Is there something to adjust or to lubricate?
Thanks, found it at the local ACE hardware store.
Guys, the rear bumper protector (stainless steel) comes loose. Can anyone recommend decent glue or some sticky stuff that will last a while? Thanks, Ed
