edgemaster
Everything posted by edgemaster
Well, the Texas heat may have played a role in summer but currently we don't have any heat at all and the mileage numbers have not changed much. Increasing the tire pressure from 34 to 38 psi has raised the mpg number by 0.3 points.
Which screen are you talking about? Never mind, found it. Thanks
The average speed display is somewhat confusing. Is there a starting point to calculate the average speed or does the calculation span the lifetime of the car? Is it possible to reset this display and start at a certain point? For example, if I enter a freeway and drive there for several hours or so and the display can be set to zero at the start, shouldn't it display the average highway speed along with the respective mpg figure and not take all the stops and slow speed before the highway entry into account? Thanks, Ed
Thanks for the hint! :-)
Thanks for the quick response. How do I get this filter out? Take the glove box out?
Hi, I have the impression that the airflow from the interior outlets is kind of weak. Is there some air container kind of thing inside the engine compartment that need to be cleaned out to increase the airflow? Thanks, Ed
Hi, I had to remove the left storage bin (next to the spare tire) on my 07 Edge SEL. In the left cubbyhole I noticed a connector closed with a cap and I was wondering if this is a pre-wiring for a trailer or maybe a rear-view camera? It has 3 each yellow, gray and purple wires plus a black wire and a ground wire connected to it. Can anyone tell me what the deal here is? Thanks, Ed
OK, thanks for the explanation, makes sense.
My 2007 edge never gets past 20.2 mpg on the highway, no matter how careful I use the gas pedal. I think that number of 26 mpg highway is just baloney! Btw, what is this "average MPH" thing? My wife saw something like 33 MPH the other day and didn't really understand what that meant. Neither do I. Can some offer an explanation? Thanks, Ed
Well, thanks for the quick response. I don't think aftermarket parts would describe their particular spray pattern. Probably have to go with the originals.
Guys, I need to replace the windshield washer nozzles. Do I need to use original Ford nozzles (probably cost a small fortune) or can I install aftermarket parts? Thanks, Ed
Can the Alldata online manual be downloaded?
Installing rear view camera
edgemaster replied to edgemaster's topic in Audio, Backup, Navigation & SYNC
Before I spend the money for a camera I'd like to find out whether or not my factory nav system has a rear connector for it. However, so far I haven't figured out a way to remove the nav unit from the dash. Can someone provide some advice on that? Thanks, Ed -
Hi, Can someone tell me how to uninstall the nav screen in a 2007 Edge without breaking things? Thanks, Ed
That is a very detailed description of the process, thanks a lot! As to the camera location, you are right, the 2007 Edge has the hatch button inside the trim panel, so that location is probably not good. I'm leaning towards a flush-mounted camera on the rear bumper. Again, thanks a bunch! Ed -
I just want to add a rear-view camera to my 2007 Pioneer system, that's all. Shouldn't a decent camera and some wires do the trick? Ed -
Nice thread but there is no info on installing a rear view camera. Ed -
Hi Guys, It looks like the Pioneer nav system in my 2007 Edge SEL is already prepared for a rear view camera. At least the nav screen allows a camera to be switched ON or OFF. So, I just need to install a camera somewhere in the rear, connect it to plus (reverse lights) and ground and pull a wire to the back of the nav system, right? Wrong? Has someone done that and could shed some light on it? Thanks, Ed
Like to sell the Pioneer nav system
One would think that the wiring and the connectors are the same. Can any of our specialists shed any light on this? Thanks, Ed -
Hi, Can someone tell me where I could buy a reasonably priced service/repair manual for a 2007 Edge? Thanks, Ed
triplejinc, thanks for the advice. I probably have to get the service manual first. Does anyone know of a source to order the manual on a DVD? Ed
Thanks for the response. Apparently we are looking at two different manuals. Mine is the Pioneer AVIC-D3 manual. On p.131 it describes the time setting. However, the displays shown in the manual don't match the ones I see on the screen. My unit is set to the default PST and I don't see any way to change that to CST summer time. The so-called "time difference screen" is NOT showing. Sorry for the hassle, maybe I'm too dumb for that thing. :-) Ed
Thanks for the quick replies. Didn't get any e-mail notifications although that setting is checked. The rolling back issue needs some getting used too, it's kind of annoying. The brakes rotors are fine as well as the brake pads. The pads seem to be new all around. This is our first car with rear disc brakes, maybe that's why the "brake feeling" is different?
Hi, Recently purchased a 2007 Edge for my wife. She has 2 questions (complaints): 1 When she hits the brake, it seems that the brake performance is sort of stop and go as if the pads would slip on a regular basis. 2. The car rolls back on very slight slopes although it's in gear. Her former Escape did hold steady on those same slopes. Can some shed any light on these issues? Thanks, Ed
Geez, isn't there anyone out there who can tell me how to set this darn clock?
