Anyone Replace Their Sony Speakers?
WWWPerfA_ZN0W replied to bill valley's topic in Audio, Backup, Navigation & SYNC
Best is to either add attachments to your post (EDIT, then MORE REPLY OPTIONS), or add links from a pic sharing site like photobucket, flickr, imgur, etc. -
Help with DRL harness.
WWWPerfA_ZN0W replied to cchenf50's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Nice, thanks! -
Best speakers for the money?
WWWPerfA_ZN0W replied to rbates9's topic in Audio, Backup, Navigation & SYNC
Do you have the model numbers for the speakers you used? Any pics of the install? -
Transmission fluid change at 22k miles (Per dealer)
WWWPerfA_ZN0W replied to SilverLimited's topic in 3.5L
City miles are basically severe duty, IME. Still makes it too early mileage wise, but not that early age wise. But if the fluid is a healthy color, has that new fluid smell, and is at the correct fill level, probably doesn't need to be exchanged. Def make sure no leaks are present. If your Edge is AWD, I'd be more concerned with the PTU. I'd get a second opinion from a reputable service shop (you can find them via Yelp, Repairpal, etc., and actually look at the reviews). -
Try them @FordService on Twitter also if you don't get a response here. Sadly, there has been quite a dropoff in their visible presence on this forum.
Backup camera guide lines
WWWPerfA_ZN0W replied to Matthewpa's topic in Audio, Backup, Navigation & SYNC
Nice of them, glad all is well! -
All done in IDS, Ford's software. So if a shop has access to IDS, it can do it; otherwise dealer. -
Video camera not configured after replacement (DTC B115E:55 may be present) DTC B115E:55 sets in the BCM when the video camera is not configured. The video camera needs to be configured through the BCM . CARRY OUT the video camera configuration using the scan tool under Body > RVC Configuration. -
Good luck!
One of the advantages of having a 4 They really should put some dielectric grease or something on the ball studs/sockets before installing the covers. Would make removal/installation SO much easier! Thanks for posting your experience, the next owner will be grateful I am sure that this was taken care of!
Long time Ford owner, new 2008 Edge owner
WWWPerfA_ZN0W replied to jonbarten's topic in Welcome Forum!
Welcome to the forum, Jon, great "bio"! Congrats on the family addition, and the acquisition of the '08! Please do put up pics of your rides past & present, also of the TBirds, if you have some you can share ... -
Welcome to the community, Bill, glad to have you here! Got pics of your new ride?
Looks sharp Kids must've helped -
With any luck they will! This would be a big win for Ford, and hopefully they are keeping tabs so they can crow about it
Appreciate it! -
Could you post a link? All I am finding is Amalie, Valvoline and Super Tech for Mercon V. TIA! Will do a flush one day for sure! Definitely made a difference even with the D/F. Spree, got pics with the new tint? -
'09 Edge SEL dashboard/console lighting
WWWPerfA_ZN0W replied to JPDR's topic in Interior, A.C., Heat, Interior Trim
enigma probably more of a reference to the WWII German code, but I too am curious! -
Modded lighting: Need help!!
WWWPerfA_ZN0W replied to TheLoudWhale08's topic in Accessories & Modifications
As far as fuses go, fuse #9 in the passenger compartment fuse panel (under driverside dash) is for interior lights & cargo lamps. #10 is for backlighting & puddle lamps. Pg. 258/9 of the owner's manual (PDF). -
I think a major idea behind tire rotation (besides even tire wear) was also to look at what's behind the wheel: brakes, hubs, all that cool stuff Regular inspection can nip problems in the bud.
FWD or AWD? FWD can be replaced per axle, might need to replace all depending on condition, like freebird pointed out. AWD unless you are replacing with same exact tire (brand, size, model, etc), all 4 at once. Again, all depends on condition of old tires.
You might be facing an AC High Pressure Switch issue, sometimes happens in these cases. Or maybe AC refrigerant level is low. http://www.fordedgeforum.com/topic/18985-2008-mkx-heating-up/?do=findComment&comment=139465
Looking to replace the TSS/OSS sensors on your 2007-10 Edge/MKX? Zazzy has posted about his experience: http://www.fordedgeforum.com/topic/19167-tss-oss-sensor-change-pcu/?do=findComment&comment=149332 Additional pics of the area by thirdgenlxi: http://www.fordedgeforum.com/topic/13407-what-have-you-done-towith-your-edgemkx-today/page-13?do=findComment&comment=124435 Video on MACT FORD EDGE on YT: https://www.youtube.com/watch?v=K-aqwVkVSvM Wondering how to replace the heater core/evaporator on your 2007-10 Edge/MKX? Zazzy is center stage once again: https://www.fordedgeforum.com/topic/17238-no-heat-decided-to-fix-it/
