edgedout
Everything posted by edgedout
Have the AC drain tube checked for blockage. While ac is on, if there is no dripping under the car it may be clogged. Happened to me 2 yrs ago. 2007 sel
When my battery went dead the remote would not unlock the doors. So I took the wife's car to the dealer to have it towed because I couldn't get in the car to jump it. The guy looked at me and said "did you try the key?" ooops
- 25 replies
- 2008 ford edge
- Tail lights
(and 3 more)
Make sure your airconditioner drain tube isn't stopped up. It happened to my 07 about a year ago. The water will also cause damage to sensors and other electrical parts. You almost have to put the car on a lift to check it.
Had the same problem years ago. 2007 sel+ The dealer replaced some part inside the remote starter. Has been fine since.
Also be aware that these ins companies will use absolutely every excuse in the book to keep from paying. If they refuse a claim, what can you do? They know you will not sue them over a few hundred bucks.
Hissing noise when AC is on and I'm turning left?
edgedout replied to Ghastly's topic in 2008 Edge & MKX
Gap coverage was the wrong term. Its a extended warranty. They did say it was a maintenance item. Of course they are reaching for an excuse. Thats how they make money. No matter how much I stated my case, no dice. They know they wont be sued over $500. -
Yes My 2007 is at the dealer right now. The tube that lets condensation from the AC(that drip under the car when the AC is on) is blocked. Thats the water you hear sloshing. In my case the water did some damage to a sensor or something and its going to cost $500 to repair. I have gap insurance(CNA) thru my local dealer but they refuse to pay for any WATER DAMAGE due to any blockage. They say its in the contract. Needless to say its the last time I get an extended warrenty. I think everyone should check this tube or have it checked every summer. Its just not something you think about, until its too late. -
07 SEL+ I have hauled 5 sets many times. It's a tight squeeze.
steering wheel controls light up?
edgedout replied to sillyjt's topic in Interior, A.C., Heat, Interior Trim
Fuse location 9 15A -
I used the trial and error method. -
Also check your fuses. That's what my problem was. -
Mileage on OE brake pads and Tires
edgedout replied to flyerjmr33's topic in Brakes, Chassis & Suspension
07 sel+ Fwd 55,000 I got rid of the oem Conti's at 45,000. Could have gone longer but one tire had a bad band that caused a thumping noise. Replaced them with Michelin LTX MS which are great. Brakes are still good. -
Yes it is luck. Akirby said "nary a repair". Then you list all the repairs you've had to do over the years. I know the warrenty is a gamble, but don't try totell this old guy if you maintain your car you won't have problems. Sometimes things break, like the AC for example.
That is a run of incredible luck. If I were you I would knock on wood, then go gambling somewhere. That's what I do. 07 Edge 53,000 miles Zero problems
07 Edge SEL + Bought Dec 08 Not one problem yet. To be fair, my wife's car is an 06 Impala that has been to the dealer once for a recall. Yes we have been lucky.
I have had those on my 07 Edge for 3 months now. They are pretty quiet so far. They look like "snow tires" but are not. $1000 otd at the Ford dealer.
Uh HELLO What part of the Op's "what you think" didn't you understand. Now take a chill pill and relax.
I fill up at the same Shell station almost all the time. A couple of years ago I was having the same problem. Then the station got new pumps and boom---problem solved.
It's been 3 years and 10 months for my 07. Still waiting for a problem. 44,000 Miles.
First detailing of 2011 Edge SEL
edgedout replied to rogersmj's topic in Appearance - Detailing, Wash & Wax
Looks great But I get tired just thinking about all that work!! -
They handle fine. I looked at alot of tire reviews online and they were 99% positive. The road noise I had was very noticable even on smooth interstate highway.
I had alot of noise on my 07 Edge starting at 30,000 mi. Thought it was either the tires or rear wheel bearing. Replaced the OEM Conti's last week with the Mich LTX-MS. No more noise.
You say idling for 2 hours "SHOULD" do no harm. And you "WOULDN'T BE SURPRIZED" if the AC wasn't affected. Why take the chance?
You asked for suggestions. Here's mine. NEVER EVER let your car idle for 2 hrs. It can cause a lot of things to happen. And all of them are bad.
