2011edgese
Everything posted by 2011edgese
Hope fully it holds up. Ford dealerships arec the worst from my experience. Also.. just threw in the KnN filter. I feel and hear no difference. Meh.
Double post
Ok... the hard code just cleared. Took 5 hours of driving here and there.
hehe. Its not that bad to do it. Link to the video when you make it.
91,540 miles. Hahaha.. ya, i thought of you when i saw it umplugged. I thought " it will fail soon."
One more thing. Hardest about doing these plugs was removing the booter hose from the rear and moving all the wires to make room to pull it out without breaking anything. Other than that. . It wasn't that bad. I think i could do it under 40 minutes next time since I'm familiar now.
From left to right. 123456 also makes total sense. This car had a loss of power at 4000rpm around 55 to 60mph. Uphill mostly. It was brief but you could feel it,but once it left around 4400rpm it would fire all 6 cylinders smooth. I put a new battery and it fixed that issue. I couldn't figure why though. Then llooking at the old plug gap, it makes sense. The gap should be around .050. But these old ones are aroung .065 to .075. Just worn out. Longer gap, weaker spark. Specially with a tired battery.
Heres a pic of alll the plugs. Engine is running healthy. Number 4 cylinder has a slight dark carbon on it. When i tried to remove the stuck boot on it and failed, i put it back but the coil spring was not aligned properly, and it didnt fire for s minute or so. So it almost fouled the plug. Removing the coil and setting the sprint straight and plugging it in again solved that issue.
opps.left the pcv hose unplugged. That's the cel trigger. I imagine its got to be driven for a while for the hard codes to clear. Other than that. .. its smoother. Im still waiting for the k n N filter. Should be here today.
Just got the cel light on. Codes p2195 and p2197. Oxygen sensor signal biased/ stuck lean Bank1 sensor 1. And bank2 sensor 1. hopefully it clears itself. They are permanent codes.
Ok. Finished. Took me 1 hour 30 min. Taking the air intake is a bit hard. Nothing crazy. . But medium hard i think. Pulling it out was not fun, all the electrical lines are in the way. You have to unclip a few of them. But once its out, the plugs are easy to get. And i got lucky. . Non of the boots stuck in the rear! Thank god! It fired up well and going on a drive. Also. .. Theres a bolt under the throttle body that holds the whole intake. I had to look carefully to locate it.
yup.. fishing is the trick. Im doing the 3 hard ones today. Air intake will come off. Im going to reuse everything if i can. Why did you say change the pcv? Does that go bad early? Or just that is easy to change while everything is out?
I tried again and this time i used a thin metal wire to fish it down and hook it with a loop and pulled it out. It worked! Managed to get the 3 front plugs. Now tomorrow ill try the rear plugs. The air plenum needs to come off. Anyone got a diagram or a idea how hard it is? Im just going to go for it and hope for the best. Also have a K n N filter coming in tomorrow. Hopefuly its worth the money. Btw.... the factory plugs had a big gap. Id say its around .065 to .070, the manual calls for. 050. The plugs i got were factory and pre gapped. Actualy. . You can't gap them. So i think the factory plugs just wore down causing a larger gap. I had a musfire at 60mph at around 4000 rpm. Loss of power ay that spot. And slight pinging. Just changing the 3 plugs ans new battery made a huge difference. Its running real good.
Thxs! Im familiar with spark plugs procedures. First time i have a ignition coil boot stick to the plug. I'm going to give it another shot maybe today.
Battery dies after only 15 minutes in accessory mode ?
2011edgese replied to wes8398's topic in 2011 Edge & MKX
broken switch? My best guess. I just put a battery in my 90k 2011 edge. It didn't strand me. Its over 4 years old. It was 540 cca. And noticed my windows would go up slower than usual after 15 minutes on accessory . I put a meter and it has a good charge. But load test and it drops to 7 volts. So to be on the safe side, i just bought a 850 cca. From Oreilly. 120$. Now it starts up fast! And load test and it does not drop below 11v. Once any car battery hits 4 years, its best to replace it. My friends 2009 xterra with 65k miles on it finally gave up and stranded. Agonist 6years. Not bad. Stranded.. but 6years not bad. -
i was suspecting Hulk Hogan preping for a come back on his door too.
Guys.. give the electrical cleaner a shot. Mines been good for weeks again. I may spray the death out of it and manualy lube the latches to prevent wd40 from contaminating the electronic contact that's failing.
poor customer service My 2011 Ford Edge Smells Like Propane
2011edgese replied to kstroupe's topic in 2011 Edge & MKX
Lol. 110$ for air freshner advice. -
I notice my 2011 whistles too. Ill look into it.
Anyone have this issue? I tried changing the plugs yesterday, luckily i just tried the easy one forest before i remove the air intake to reach the back. Well... when I pulled it, the coul boot stayed withbthe plug. There was a spring on top of it, i just plugged the coil back on and luckily it fired up fine. Do i stopped there. How would you guys approach this? Wd40? Long fliers? Coat hanger? Im scared i will tear it. Im aware you can buy the boot online but ud like to save them. Also. . What was that spring thing on top of the boot? Is it just a contact of current? Id imagine that's the purpose. Anyone changed the plugs and how long did it take you? I think all of the plug boits will be frozen. I have 91k miles and original plugs.
Lol. Spraying the keyhole only helped for 3 days.came back. Did my oldprocedure of spraying keyhole and latch with a lot of the cleaner. It's been gone for two days total again
Double post
I hate dealers.lol. find a good independent shop you can trust over time. Unfortunately it's hard to find a decent shop that won't rip you off.
Don't have this issue but when you have mushy pedal and everything has been replaced and bled, then I'd the abd pump hasn't been bleed properly with a scanner then chances are that there is air in there. It cost money to have the scanner plugged in and bled but might be worth it in your case to eliminate that possibility. On a prior car, I had 3 rebuilt brake master cylinders that were faulty out the box. That was my issue.
