Jlk was right. I drilled the drain hole for my ptu today and no oil came out. Everything was significantly more messy than a few months ago. Mostly from the vent not the seals. I feel like no one has documented drilling the drain plug with the ptu in the car, so I snapped a few pics. These are from an 2009. There is just enough room to work between the exhaust and motor mount. I drilled a pilot but not all the way through to keep the chips on the out side, until the end. 5/16 was enough to keep the 37/64 drill from walking. The casting is surprisingly thick. About 1/2". Do be sure to stop And oil the drill a few times. I left oil in the pan to push out the chips when I finally broke through. A 16mm socket and extension holds the back of a 3/8" npt tap and allows me to reach past the exhaust. Use grease so the chips stay on the tap and out of the case. I run npt taps about 2/3rds in. I was taught the plug should go in about 2 turns by hand before you need a wrench. And tightened an additional 2 turns with a wrench. It takes a little back and forth. Do Not cross thread the tap when putting it back in. I picked up a magnetic drain plug from mcmastercarr.com. but i'm sure amazon has them too. Do not cross thread the drain plug when putting it in.
