rafeeki
    2
Everything posted by rafeeki
  1. Took my Edge in today. The wording of my complaint was "Transmission is jerking when slowing to a stop" They performed according to TSB-19-2331 which is basically reprogramed PCM and performed adoptive learning drive cycle. So far after driving 5 miles its performing like a charm better than my wives' new hybrid Venza and quieter. I'm keeping this vehicle until Ford comes up with an EV Edge or similar. Thank you all for your contributing to this "Jerky" cause.
  2. Jason No, I didnt take it in yet. Pl see my entry above yours.
  3. Thank you gents for your in depth investigation into our Buck & Jerk issue. In order to explain the issue to my service guy at the dealership I wanted to be able to describe it clearly. So As I am in the Chilly Chicago area I thought I needed to determine under what conditions it starts bucking. Here is what I found out. 1. Temps in high 20's 2. Had to drive it for about 20 mins before it exhibited the bucking/jerking performance. Apparently had to warm up. 3. It was mostly obvious while driving around a shopping area parking lot with a lot of stop signs.. Next week im scheduled to take it in. Will advise when I have something to contribute. Again thank you for posting here. Rafeek
  4. I have 30000 mile on it so far. Lease expires in June 22. I wonder how much of the drivetrane warranty will cover in case the transmission konks out? I'm intending to buy it at end of lease and keep for an additional 2 years.
  5. Since my issue of jerking is noticeable while coming to a stop from a reasonable speed I suspect it could be due to either the transmission downshifting or the antilock breaks kicking in. Has anyone pursued that angle?
  6. I have the same problem with my 2019 edge built before Nov 2018 On a whim I thought of mixing it up and used S mode then went back to regular mode. There was a marked improvement. I also tried using my paddle shifter and got up to 8th gear, it has to be at approx. 2000rpm or greater to kick in. My suspicion is it has to do with oil flow in the unit but that is my uninformed suspicion. It's worth trying it.
  7. I have the same issue with my "grabby" sensitive breaks on my 2016 Edge. The dealership could not duplicate it on a test drive so they are not repairing it. The car was built on 04/2016 which puts it out of the booster recall. Am at a loss. Any suggestions
  8. No mine are satisfactory. I don't miss the fog lights I had on my 2007 Grand Cherokee as what I have here is just right. Do we have auto dimming headlights? I have a Limited Ecoboost.
  9. It now says "insert new SD card". Taking out and reinserting the card doesn't do anything... Has anyone had this issue?
  10. It now says "insert new SD card". Taking out and reinserting the card doesn't do anything... Has anyone had this issue?
  11. rafeeki
    Tint & the law..
    I feel that the front windshield should be partially tinted along the top as there is too much glare, I have to drive with the sun visor down all the time. Does anyone have this issue? Rafeek
  12. When my right foot hits or leans against the plastic wall by the gas pedal it sounds loose. My foot could also get caught on the stuff (vents) just right of the gas pedal.. They should move that stuff out of the way. The left plastic wall is also loose as u push against it, it rattles. This sounds very cheap. Rafeek
  13. I have the same issue on my 2013 Edge. Found out that deleting it from my phone then reinstalling it did the trick for now.... I have had it for 2 weeks so far and am thrilled with the car:)) Rafeek
