sel edge
Everything posted by sel edge
  1. Looks good. Do u know the hub size?
  2. Who makes the flat wheel spacers for our cars with the right 63.4 hub? I have some 22" strada wheels with a 40 offset and the correct hub centric ring cause the wheel hub is 72.6 and the spoke wheel is very close to the caliper. I need a 3mm spacer and ill be good to go
  3. Whats your wheel width?
  4. Im not worried about the gap im going to lower it once i get the tires im more concered about the tire width. The ford dealership told me the 22" sport wheel is 9" with the 265 and my wheel is 8.5" and alot of websites say 8.5" is to narrow for a 265. I wanna see what tire size people are using with a 8.5" wheel on 22's.
  5. I jusy picked up a set of 22" wheels with a 40 offset 8.5" width. Im thinging a 265 is alittle to wide and should go with a 255/35r22. I dont want the sidewalls to buldge out. Any info or if u have this size could chime in on this subject.
  6. Ok ive been searching and found that they dont recomend cables or chains on the 20" wheels due to clearance between the tire and strut but what if i install a 5mm spacer to gain some clearance. Has anyone tried this? I wanna go up to the snow this weekend but its kind of sad that a small suv cant go with cables vs a honda civic with cables can go no problem.
  7. Ok i did trim the tabs with a small 1/4 inch triangle shape file works perfect. Ill turn the bulb in a different position to see if it takes care of it. Thanks
  8. I just installed the hid kit from day time bright lites which look awsome but on the driver side theres a shadow thats showing up how do i fix this.
