Everything posted by thesavo
I gew up with my parents owning these 1990 Econoline 150 conversion van 1994 continental 1998 Town car 2004 Town car My own Fords 1998 Explorer sport - trans died 2003 Taurus SES ax4s - trans died 2008 Mariner - still running at 200,400miles 2014 Edge SEL - inhereted Now my wife wants to add a 2022 bronco 4 door.
Aftermarket hitch and drilling
thesavo replied to thesavo's topic in Cargo, Hauling, Roof Racks & Towing
Thank you. I did not see this option when I checked prior. Perhaps I did not scroll far enough. I have an SEL not sport. Do you think that would be fine? -
All the aftermarket tow hitches for a 2014 SEL I see requires drilling two holes out of six bolt holes required My wife and I will rent a 5x8 uhaul trailer once In a while. There will be no camper pulling here, unless it's a tiny tear drop one under 2000 lbs. Does anyone have a recommendation to prevent rusting where holes are drilled? I live in upstate NY and, well winter.
I got the net effect I was looking for by removing Sirius from the lineup on the Touch screen,. I almost never use the right cluster screen. I still need to remove it from there. At least this looks better to me. Thanks DaMiFo for stating that the order is fixed.
thesavo replied to ben senise's topic in Accessories & Modifications
I just skimmed through this entire thread, looking for, and did not see a dedicated shared spread sheet to First and second Gen Ford Edge. I have a blank one started. https://docs.google.com/spreadsheets/d/1rJsdm8IpDyhjgKjnugyd-Xv4ULdl3JCQU7lS7TvsIPQ/edit?usp=sharing -
I have a 2014 Edge and 2008 Mariner with Redundant Radio Steering wheel controls. Both of them function in the same manor and I would like to change this default behavior. Currently, tapping the Previous << and Next >> buttons will scroll through the radio presents in an expected direction. Holding or long-pressing them will seek the radio to previous/next available strong station. I would like to swap the behavior around . This would make SEEK the tap operation and the next-preset operation be the long-press or hold option. I have found few threads talking about this and no threads talking about it here. I have cross-posted to ForScan Forum. I know when I added Steering wheel controls to my Mariner I had to edit the row. My original As-built 727-01-01 0040 D08B E0XX I changed the D to a 9 and the E to a 6 727-01-01 0040 908B 60XX Does anyone else desire this same swap? I find it funny that tap'to-seek is the default function on my 2014 jeep patriot. Other threads discussing this https://www.ford-trucks.com/forums/426389-reprogram-seek-button-on-steering-wheel.html https://www.ford-trucks.com/forums/1570699-can-you-change-the-function-of-steering-wheel-radio-controls.html
I have attempted to research this but am coming up empty. Has anyone here tried changing the Order of the Radio inputs with forscan? I would like to move the BT audio a little higher in the list, as it is on the the second "page". I think i may have to accept that the order is static and I should removed Unused inputs. Perhaps removing Sirius radio from the list would help. I found this to remove Sirius, but have not had a chance to change it. APIM 7D0-01-01 *xxx xxxx xxxx Decrement existing value where the asterisk is by 2; if you have an "A" make it "8", if you have "2" make it "0" url: https://www.fordedgeforum.com/topic/27415-removed-siriusxm-from-main-audio-display/ https://www.fordescape.org/threads/remove-sirius-from-mft-menu.84506/
In case you were wondering, yes a wireless charge cradle this close to the ignition will interfere with PATS on start. I found it best to cradle the phone after starting the engine going forward. I plan to move it a bit higher. Not a problem, more of a PSA.
I agree that web-formatting aside, it is nice to be able to consolidate all the forums I post to in the same app. Like a podcast aggregator for forums .
Disable MyKey limitations
thesavo replied to JMEdge's topic in Alarms, Keyless Entry, Locks & Remote Start
I know this thread is six years old. However for those coming in from web search, I had the same problem. I solved it with the following: - windows laptop - Latest version of forscan, and a two month extended license trial. - a newly cut copy of an 80-bit key (non integrated remote) from Amazon.com- cost is under $15 - obdlinkmx Bluetooth dongle from Amazon.com - Discontinued now. You can use forscan to program additional ignition keys. I didn't have to erase all, just add. Procedure here. https://www.forscan.org/forum/viewtopic.php?f=16&t=10230 Note: Amazon URLs are non-affiliate link -
Jack points and jack stand placements?
thesavo replied to Vortechtral's topic in Brakes, Chassis & Suspension
What about Gen 1? I am working on a 2014. Once you use one of four pinch welds to jack up, What's the appropriate place for a jack stand. What do you all use.? -
I too am looking for a guidance on jacking and lifting this vehicle. I guess we solved the Jacking point issue. We should Use a cut hockey puck or rubber pinch weld adapter. What are good Jack Stand location, besides, "there are plenty". Many owners have felt confused on where to find a appropriate lift point. I would think some senior member would be nice enough to clear this up with a pinned post on what "their" jack points and jack stand recommendations are. -
https://www.youtube.com/watch?v=xvUr_k4j9gc 3.5L and 3.7L Duratec Engines Water pump Failure
IS all dexcool compatible? The owners guide for Model Year 2013 and 14 calls for WSS-M97B44-D2 not D. I am also looking for clarification. There are ford documents that state you can Use D2 fluid where D is called for. Nothing states that the reverse is true. I found another document that states D2 is pre- diluted and D (proper) is undiluted. My fear was D2/D compatibility was similar to the old Mercon vs Mercon V issue. Where Mercon V could be used in all applications that Mercon (proper) was called for. Source: https://www.fcsdchemicalsandlubricants.com/main/quickref/coolantsEN.pdf http://spautoparts.com/documents/CoolantFAQs.pdf
I have to troubleshoot the horn on my mothers 2014. According to this it is in the passenger side fender somewhere. What kind of work am I in for just to the check the wiring?
Compliance Recall 18C06 – Incorrect Door Striker Bolts – 2018 Ford Edge & Lincoln MKX oemdtc September 20, 2018 Recalls NHTSA Campaign Number: 18V612 Manufacturer Ford Motor Company Components LATCHES/LOCKS/LINKAGES Potential Number of Units Affected 503 Incorrect Length of Door Striker Bolts/FMVSS 206 If the doors open in the event of a crash, there is an increased risk of injury. Summary Ford Motor Company (Ford) is recalling certain 2018 Ford Edge and Lincoln MKX vehicles. These vehicles may have door striker bolts that are shorter than intended. Vehicles with shorter door striker bolts fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 206, “Door Locks and Door Retention Components” potentially resulting in the doors opening in the event of a crash. Remedy Ford will notify owners, and dealers will replace the door striker bolts, free of charge. The recall is expected to begin October 15, 2018. Owners may contact Ford customer service at 1-866-436-7332. Ford’s number for this recall is 18C06. Notes Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov. Check if you Vehicle has a Recall September 12, 2018 TO: All U.S. Ford and Lincoln Dealers SUBJECT: NEW VEHICLE DEMONSTRATION / DELIVERY HOLD – ADVANCE NOTICE Compliance Recall 18C06 Certain 2018 Model Year Edge and MKX Vehicles Incorrect Door Striker Bolts AFFECTED VEHICLES Vehicle Model Year Assembly Plant Build Dates Edge 2018 Oakville July 27, 2018 through July 31, 2018 MKX 2018 Oakville July 27, 2018 through July 31, 2018 Affected vehicles are identified in OASIS and FSA VIN Lists. REASON FOR THIS COMPLIANCE RECALL Some of the affected vehicles may have an incorrect shorter length door striker bolt installed, and may not conform to the requirements specified by Federal Motor Vehicle Safety Standard (FMVSS) 206: Door Locks and Door Retention Components. Reduced door striker strength may allow a door to open in a crash, increasing the risk of injury. SERVICE ACTION DO NOT DEMONSTRATE OR DELIVER any new in-stock vehicles involved in this compliance recall. A complete Dealer Bulletin will be provided to dealers by early 4th Quarter, 2018 when it is anticipated that parts ordering information and repair instructions will be available to support this compliance recall. IMPORTANT: Dealers should open a Repair Order (RO) only when a full dealer bulletin is published. Opening an RO against an Awareness or Advance Notice will result in warranty rejections against a recall. Source: https://ford.oemdtc.com/3950/compliance-recall-18c06-incorrect-door-striker-bolts-2018-ford-edge-lincoln-mkx
no update? -
I have a 2014 and starting today the radio on the touch screen says "entertain unavail." I reached out to ford sync chat and they said to do a master reset. I did and also stopped and restated the vehicle. The problem remains. I found posts saying some other vehicles had this issue, and they say to pull fuse 27 or 35. That doesn't correspond to the 2014. Edge. They are blank. Also, the cluster screen to the right of the speedometer, reads "temporarily lost communication with the touchscreen"
Did you find your Tach? If that is a picture of your cluster you may need to take it out of "transport mode"
My mother just recently purchased a 2014 Edge from Depaula in Albany. It was very pleasant experience. They even provided two ignition keys.
Fantastic, that's very helpful information. Thank you.
I am purchasing a 2014 Edge, and I did a TSB search revbase. I found that TSB 14-0175 that might apply. The TSB discusses the ambient lighting exhibiting issues. I checked the buildlist on etis . It doesn't list "ambient lighting". It does list Less Interior Light Group. IS the Interior Light Group the name for ambient lighting?
I'm trying to get the dealer to sell it with a second key. Thank you for the update. Have you tried Key programming with ForScan, or is that too risky? So these are 80 bit keys. 5912560 5912512 These seem to be the Strattec part numbers listed as compatible with a 2014 Ford Edge that I am in the process of purchasing. Unfortunately it's coming from a Chevy dealer, and I am loosing the battle to have them to include a second key at no extra cost.
We just started the sale on a 2014 Edge with the newer IKT type ignition key. Is this just a normal 40 bit key that has been in use since 2000? I just had a discussion with the sales manager. I told him that the key is cheap enough and i would take even a non IKT.
Thank you very much. Exactly what I needed.
