Everything posted by thesavo
rear noise rear end "thump" noise in sync with vehicle speed
thesavo replied to thesavo's topic in Brakes, Chassis & Suspension
I am not ready to condem the cv axles ad the noise is gone and speeds under 30mph . I have an alignment today and will followup if any $ sounds happen at highway speeds. Then the only issue will be the parking brake on the driver's side. That can be tomorrow's issue. -
Just the opposite. I just took it for a test drive. I wasn't able to get up to 60 MPH, however the sound is gone at slower speeds. Since I removed the rear Knuckle (spider?) I want to get a 4-wheel alignment before I get it up to highway speeds. The parking brake not holding on the driver side will need to be addressed though. The Passenger side parking brake is holding the vehicle off the park pawl. -
I have installed new wheel bearings and even with both wheels off the ground, they move much smoother than before. I also replaced the sway bar links, and the passenger-side wheel-speed sensor. (Buy an inductive heater if you don't have one. /Chef's_Kiss) I am still not sure if I have a defective replacement driver caliper or a cable issue as that side does not hold as well as the passenger side. The service procedure Pinpoint test says to 1. check for broken cable. (driver side cable shows no damage) 2. check for pad thickness (Brand new). 3. Brake pedal and control cable move when disconnected from the equalizer 4. Disconnect cable from caliper and move the cable in and out of the conduit. - yes - replace the caliper - no - replace the cable on the affected side. Also, I am able to move the parking-lever on the back of the driver caliper manually (no cable attached) to actuate the parking brake. The lever moves more freely and farther on the Driver side than the passenger. Again, no cable attached. The service manual shows no adjustment to be made here, only at the "equalizer" I did try to remove the nut holding the parking lever to the caliper, and tighten the inner bolt as shown on some performance calipers, but the lever stays on the pivot bolt. The Driver side cable seems to expose more of the center of the cable at "equalizer" when setting the parking brake. I seem to have conflicting symptoms -
We shall see. I can't say as my wife made no mention a noise leading into our last trip in late September. The noise started late into the trip. I'll update as it progresses though. -
Sadly as another friend was called in to assist, the passenger side bearing we started on was not in a trustworthy state of being tested. Through I will say we didn't impart the same force on the driver side bearing as we were able to remove all the remaining bolts to remove the knuckle. It did have some drag while trying to spin. As a note. There is special tool to separate the knuckle from the control arm. Though do remember to loosely re-install the nut on the joint connecting the knuckle to the control arm before using the press, or you will need an angle-grinder to repair the threads. If anyone else is attempting this in the salt-belt, I would advise to remove the knuckle completely and use the services of a machine shop to press the bolt-on bearing from the knuckle. It doesn't separate as easy as many youtube videos would have you believe. I will be making use of silver never-seize when installing the replacement bearings. Video removal https://youtu.be/8lpb7_TarU4?is=eMjgVEoQMRU1bhlA Special tool https://shop.advanceautoparts.com/p/performance-tool-ford-ball-joint-separator-low-profile-w83051/50159995 -
Thank you Samurai Edge for your response. The sound did emanate from the rear of the vehicle, though pin-pointing to one side or the other was in conclusive. The tires are only 2 years old with no visual signs undue wear. A nail what noticed in one threads, however this discovery was minimized by a shade-tree mechanical member of the family as "being beneath the death of thread" as the sound can be heard starting at such low speeds. So on Sunday, I made a failed-attempt to unbolt the wheel bearing from the knuckle and isolate it from the drive-shaft non-destructively. To make a long story short, this did not workout. A 55-ton press was required to remove the (bolt-on) wheel bearing as attempts with traditional slide hammers and hub pullers lead to another failed attempt with the an Orion puller. https://a.co/d/09GzRjxl New wheel bearings are on order from Detroit-axle which has been a good brand of brake and suspension parts in the past. -
This is a 2014 Edge 3.5L SEL AWD with 161,000 miles. For the past few weeks we now there has been a "thump" noise that is in sync with vehicle speed. I can upload a video of the noise, but is is the sound of "thump","thump"-"thump"-"thump and gets faster with an increase in vehicle speeds up to highway speeds. We were late in to a road-trip when it started. We had a tire-shop rebalance the tires, no change in noise and frequency. The inward pad on the driver side was worn almost down to backing of the pad. The passenger side seemed to have even wear, however the piston was equally difficult to react as the driver and boot was torn up. I changed the rear calipers. The calipers were targeted as they needed an extreme amount of torque to spin the piston back into the caliper. I tried to bleeder trick to determine if it was a bad caliper or brake hose, by pumping up the peddle 4 times and cracking open the bleeder screws. They only dribbled out and I still needed way too much torque to spin the pistons back in. Now, having replaced the calipers, the brakes work fine, however the parking brake doesn't seem to hold as well. I'll work on that in another thread. The passenger side holds better than the driver side. The "thump" noise is still present while driving as slow as 2-3 miles per hour. There is no left-to-right or up-to-down movement when shaking the tires on either side. Before I reload the parts cannon with rear-wheel bearings, what further troubleshooting should I try next?
I know this is an old thread but it was continually revised every few years. I'm concerned about drilling out this dimple thing on my 2014 SEL. Also can any one scan a copy of the install instructions?
Removed Sirius/XM From Main Audio Display
thesavo replied to Gadgetjq's topic in Accessories & Modifications
Any chance you were able to remove it from the Guage cluster too? -
So my wife and I had a few mis-starts with the remote start after adding an authentic RS key. 1. Press [LOCK] button on IKE 2. then double press [2X] button the parking lights would double flash and it would not remote start. I found the pin-point troubleshooting guide in the 2014 factory service manual. For those that are looking, it is under Engine starting not RKE. GROUP 3 - SECTION 303-06: Starting System Pin Point F is for remote start. I attached a PDF that contains only pinpoint F and separate PDF of DTC chart if it is needed Again, PinPoint test F is consolidated and just pertains to remote start. PM me if anyone needs the entire section. As soon as I had the troubleshooting tests in my hand, the remote start worked and I had nothing to test. So, Murphy's law for now. I have it ready in case it fails again. Edge-StartingSystem__PinPoint_F.pdf Edge-StartingSystem__DTC.pdf
I can confirm, the keys included in my kit are my problem with range and intermittent remote starts. The generic keys are not good. I replaced it with this from ebay and works like it should. Authentic rs key from ebay. I paid $110 after shipping. https://www.ebay.com/itm/NEW-OEM-2011-2018-Ford-Remote-Head-Key-W-Remote-Start-164-R8067-5912561-SEALED-/400622189183?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0 I spent $277 between the kit with bad keys and one good key. I would been better off buying the $150 kit from fairway.
I'm sorry that the major hardware stores gave you such a hard time. I usually get a little push back as well. When I tell them "it's OK to say no to transponder key" they look at me strange. I just tell them I have a way to program and I'm not worried about it. I have never left with an uncut. Transponder. I just left Lowes and said to the kid , "scan your bar code for blank #24, but insert my key at the time of cutting " I typically offer to pay for the cut on my own key and after that they say, "no problem and, don't worry about it"
2014 edge SEL entertainment unavailable
thesavo replied to thesavo's topic in Audio, Backup, Navigation & SYNC
Sorry for the long delay. I know it is bad form to leave a question un resolved. This issue only came up once. I was not in a position to work on the issue and it has not come back. As my mother was the primary driver, he hadn't reported the issue came back. In March, my wife and I inherited the vehicle and the issue has not come back for us. -
Update. The Generic kit that I got earlier this year is having an issue. This is the kit that I bought and would not recommend it. https://www.amazon.com/gp/product/B08YQT3V2Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 The generic keys that came in the kit seem to have defective RS buttons after a few months of use. I would recommend a kit with better aftermarket keys or the official $150 - $300 kits from ford. I am having difficulty finding the keys alone. As stated in the first post of this thread; 164-R8067 is a supplier part number. When I search for that i get this link below. https://www.carandtruckremotes.com/factory-ford-remote-key-164-r8067.html They seem to have official remote start IKT keys and ilco aftermarket keys - Official ikt Price: $139.95 - Illco Price: $39.95 Official Ford kit. $150 https://www.fairwayfordparts.net/p-1-key-remote-start-fits-f150-super-duty-edge-and-flex-164r8067da8z15603a $300 https://accessories.ford.com/products/100-series-plug-n-play-4-button-remote-start-system-1
I ordered a Bronco Sport in March and took delivery on June 23. I traded In the mariner at 20200.4 miles.
HI All. I have read though some of the other discussion on hood struts . Some of these threads are years old and I am curios if anyone is having rust issues with these in the northerns states. I have a 2014 that I plan to keep and would like to add them. I plan on getting a bolt-on set for my Bronco Sport. However the model for the Ford Edge require Drilling. Does anyone have a status update for their installs of these kits?
Aftermarket hitch and drilling
thesavo replied to thesavo's topic in Cargo, Hauling, Roof Racks & Towing
So. I called etrailer. The model they make for SPORT is not compatible with SEL. They even added it to the faq. https://www.etrailer.com/question-525555.html?fb=yes Now, I did find that Ford offers a oem hitch on the accessories site. It also claims no drilling and not sport compatible. So I may have found what I was looking for. https://accessories.ford.com/trailer-hitch-8755.html#2014/Edge I'm looking for install directions. Part number BT4Z-19D520-A -
Thanks for this.
Curious. I have a 2014 with sync2. How can this be achieved? I have searched and not found a good guide yet.
OK, This worked. I can confirm you can install ford a Ford Plug n Play remote start kit in a 2014 ford Edge SEL w/o power liftgate. These Kits are sold for F150, and super-duty trucks. Watch any truck install video and it give you an idea. The pictures from another post show where the target module is behind the driver's rear quarter trim panel. Use care when pulling it out. I did not take a picture, but you don;t have to rip the entire panel out. Just pull it back near the top of the seat belt. The TPM module is mounted to the Trim panel. Purchased parts - BT4Z-19G366-A Hood Switch - BC3Z-19G364-A Remote start kit. 2 (generic) keys, antenna, and RF cable. I did not have to mess with As-Built codes as it had "presets" ready to go for BdyCM and IPC module. IPC changes were expected from previous posts. With all the Remote options added, just one row of AS-built changed. BdyCM changed as expected, however, it did change block 57. I compared exports before, after and then compared them with win-merge. I forget to take screenshots of block 57 in forscan. Since the Keys were clones, the Key Transponder had to be programmed separately from the remote built in to the key had. For the remote part, I had to program with 8 key cycles then press buttons on the remote. For some reason, generic keys are just a transponder pill and and remote fob kluged together The Clone keys have a 2x button, but it takes 3 presses after lock to start the car remotely. I am not sure why, but it does guarantee a start every time. Here are links to amazon items that I ordered. https://www.amazon.com/gp/product/B08YQT3V2Y/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00BI1CHCE/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
My key settings is really to see how many programmed keys there are. I'll find a video of the menu for you. I'm still hazy on the parts needed. I updated another thread asking to confirm parts. You should pull the driver rear quarter trim panel. That will show you if you have the remote start antenna. You can also check your Vin with a free account at etis.ford.com. You can pull your as built config from the factory wit Motorcraftservice.com/asbuilt
It's odd that your key would have a 2x start button and not have remote start. It could be that the key you have is all that was available to the dealer or the previous owner when a key copy was made. You can sign up for an account with the Ford site below and check if you had remote start from the factory with your Vin. Etis.ford.com Also, how many keys do you have now and have you lost any? You can check the number of programmed keys in the cluster (IPC). Look for my key if it is an activated feature, it will tell you how many total keys, admin keys there are and how many "mykey" keys. Mykey is in the cluster settings, be sure not to "demote" your only key to a mykey. If there are more keys than you have, it would be likely, it was the only keyblank available. It would also be a diy programming or an inexperienced Lock Smith as a dealer would have erased other lost keys. If remote start is as plug n play as we are lead to belive, you need the following done. - Hood pin switch on the driver side. - working key with a 2x button that you already have. - a bar type antenna behind the quarter panel on the driver side. - (lastly) remote start enabled in your body control module. You can check the body control info with a windows laptop, obd reader like obd MX and a free copy of forscan for windows. This is in the bdy as built codes. Check out the quarter panel first. Link: 2011 Ford Edge 200 Series Remote Start DIY (BB5Z-19G364-C) QUARTER PANEL Removal instructions. The remote start setup is over complicated
I have a 2014 SEL with a non power lift gate. I have re read the thread and I summarize i need the following. Would a forum adult please check my work? I plan to do all the work and not need a Dealership trip and Rotunda IDS. I have seen talk about needing a VSS module or an RMST module. IS that still a requirement on 2014 as i heard it was just Add the bar antenna, enable in IDS, and cut/program keys. I have no requirement for Cellular remote access. I only want to remote Start with IKT. I have no want for another fob to hang off my keys. - Hood Pin Switch - BT4Z-19G366-A. Very helpful pictures provided in another thread by @j3st3r - series 100 w/1 key - BC3Z-19G364-A - Enable Remote Start Function - As-Built Code - Taking codes from Explorer Forum, and @Tim Mallon here on Edge Forum BCM - Suggested 726-19-01 0047 = remote start disabled 726-19-01 0148 = remote start enabled - Enable Cluster Remote Start Climate options - TBD IPC remote start options - Suggested 720-01-03 C8F3 = without climate seats or wheel(Base model and Interceptor. Possibly some XLT models) 720-01-03 F823 = without heated steering wheel With climate controlled seats 720-01-03 FC27 = with heated steering wheel With climate controlled seats My AsBuilt w/o Remote Start - motorcraft.com/asbuilt BCM - 726-19-01 0047 IPC 720-01-03 002B - PATS Key Programming - ForScan service procedure References found. Link: 2011 Ford Edge 200 Series Remote Start DIY (BB5Z-19G364-C) QUARTER PANEL Removal instructions Link 2011 Ford Edge 200 Series Remote Start DIY (BB5Z-19G364-C) Hood switch Installation Instructions Link: Edge Form - Adding Remote Access to 2013 edge xlt Link: DA8Z-19G364-A Remote Start Link Ford Edge Forum - Comprehensive List of Possible Forscan Mods Link: 2013 Edge - Remote Start Kit - 100 Series Plug n Play (BC3Z19G364A) installation & Activation Link: Explorer Forum - Remote Start I am guessing that BC3Z-19G364-A is Kit that combines the following parts from above - DA8Z-19G364-A 5 button keys only. $241.95 - DA8Z-15603-A Antenna Kit. $25.30 Which IKT;s Should i Get? MY OEM keys are 3 button and My 2014 SEL has w/o power lift gate. I have programmed late 90;s fobs to it and they have trunk release buttons, but they do not release the liftgate for manual opening. On my Mariner it releases the liftglass. Since the ford Edge has no lift glass; is the double press trunk button able to be enabled for vehicles w.o power liftgate? I think I answered my own question, but is the trunk button only meant to power liftgate. Since I have no plan to add power liftgate, would I be best off with 4-button remote start? Update: 4/28 I'm going to order the following and see how it goes. - antenna module with rf cable and 2 keys - a hood pin switch I feel the RMST module may not be required. Update:5/3 . The kit arrives on Tuesday. I'm anxiously waiting. I'll only cut one of the keys for now; as the primary driver is the one that cares for this feature.
HI. I know this thread is two years old, but did you ever find the IPC as-built code to remove Sirius from the cluster entertainment screen? Asking for a friend. -
It's been two years. Did you get a chance to perform this mod? I added this to my 2003 taurus years ago. I have diagrams for 2014 if you want. Do you have have a door with the cut out or are you using a grinder?
