Everything posted by flymore
Jack points and jack stand placements?
flymore replied to Vortechtral's topic in Brakes, Chassis & Suspension
Thanks, I'll try that. What about the rear wheel? -
Ok found the arrows. Took a bit of scrubbing! New problem - I took a piece of 4x4 and cut an indentation in it. But when i jacked up the car using the 4x4 it split the 4x4. Any suggestions on what to use? thanks. -
Gearing up for my first tire rotation on my new to me 2018 Edge AWD Titanium. The owners manual indicates there are "arrows" that show the lift points, "9. The vehicle jacking points are depicted by arrows on the underside of the vehicle at the locations shown above." I'm not finding the arrows that indicate the lift points. The second question is the rotation pattern. The manual clearly states that for FWD and AWD vehicle use this pattern. There is another post that states for AWD vehicles you must use an X pattern where LR to RF and RR to LF. RF to LR and RR to LF. "On four-wheel drive and all-wheel drive vehicles, the recommended rotation pattern is a “Double X” so the right front and left rear tires switch positions as do the left front and right rear." https://www.tireindustry.org/tire-maintenance/tire-rotation Thanks for any help. -
Ok, thanks
That's great. Thanks
Just changed the oil in my 2018 Edge AWD. The manual says to rotate the tires when the oil is changed, will this mess up the TPMS? Is there a procedure to reset TPMS after I do the rotation? Thanks
Nope don't live in hilly area, kinda lead to the question cause I generally don't use the parking brake or have need for it. Funny, after I use the electric parking brake the brakes seem to grab better. Thanks
Do you set your electric parking brake every time you park your Edge? Does setting the electric parking brake adjust the rear brakes and so this is something you should do? Or does using the parking brake all the time lead to premature rear brake wear? Thanks
Did you purchase your 2013 Edge new? Have you changed the fluid in your PTU during the time you've had the Edge?
The touch and release, doesn't always work...So with my Edge it's more of a hold and release. I'll look for the advanced option and try that when i get a little more familiar with the system. thanks
Ok, I'll try just having her change the temp. I noticed that if I change the temp on my side, it changed both sides. I'll have her try it. Thanks
No I don't mean cruise is "engaged" when you start the car. My Chevy had a switch for cruise you left it on, it was ON when you started the car then when the car was moving you press SET to engage it. With the Edge you always have to turn it on then press SET. Turn it on then press set. Turn it on then press set. With Chevy it's on so you just press set. Just press set at the speed you want above 25mph. Just press set at the speed you want above 25mph. With my Edge it doesn't remember that I left DUAL on so I can have different temperature than the passenger side. Every time I turn the car on I have to set DUAL and turn on cruise control. Start the car set DUAL in climate and turn on cruise control. Start the car set DUAL in climate and turn on cruise control. I'm now using the buttons on the right hand of the wheel to navigate to source, but it's several steps and I sometimes have to take my eyes off the road.
With the climate control I have to go in menus and turn on DUAL, so my wife can have a different temperature on her side of the car than mine. Would like to have DUAL on by default, there is no safety issue here with DUAL climate. I don't see the risk with leaving the cruise on, it doesn't engage unless you press SET and the car is moving over 25mph. So how is having the cruise off safer? Yes I can change the source with a voice command, I have to hold down the voice command button, wait for it to stop speaking then say what source I want and sometimes it doesn't understand me. A simple button would save time.
Three annoyances, 1. No source button. Using the menu or keypad distracts you from driving. 2. You have to turn the cruise on every single time you start the car. My previous car had a button that locked in the on setting. 3. Dual climate control has to be chosen every time you start the car - why doesn't it just leave dual climate on!
I'm enjoying my Edge, but one thing I really miss from my Chevy is the source button on the steering wheel. The source button allowed me to switch from AM, FM, CD, Siris XM and alternate input. The only way to switch sources is to activate the voice command or take my hand from the wheel and eyes off the road? This is a bit annoying with other people in the car and you're talking to them.
What year/how many miles on your Edge? AWD? Good luck with the Subaru, they're very popular. A little scary for new Edge owners like me. ?
It was a nice day, about 60 degrees so I decided to crawl around under my new car. After a couple of short trips the temp of the PTU case was 196 degrees. The drain plug appears to be 1/4inch hex. I think someone posted it was 8mm, no way. 7mm way to big and 1/4 fits well with just a tiny bit of play. Do they make 6.5mm or is that to close to a 1/4? I don't have a 6.5mm in my set. It's really tight in there and still not sure I want to do this myself.
Sync 3 & CarPlay problem Arrgh!
flymore replied to timfountain's topic in Audio, Backup, Navigation & SYNC
The wifi in my new to me 2018 Titanium appears to work fine. Connected to my home wifi with my password and had it search for updates and none were found. However, I've only had this car a month so far so good. -
Assume you have a 2019? What engine? My 2018 3.5L AWD is not doing that. That's not good, take it to the dealer ASAP.
Got my window sticker here free with the vin, https://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html Am told this only works if the vehicle is at a dealer. Mine was a CPO bought from the dealer. Good luck.
Welcome, Got my window sticker here free, https://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html
I'm new to Ford and just recently purchased a CPO 2018 3.5L with AWD and enjoying it very much. You say the PTU failed at 150,000 did you service the PTU during it's life? If so when? Many recommend the PTU be serviced, but I discussed this with the dealer asked them to service the PTU but they insisted it doesn't need servicing till 100,000 miles. Fyi, my Chevy pickup 4.3L v6 drank some antifreeze most of it's life through the intake manifold. This is common. Just saying that if the antifreeze is disappearing it may not necessarily going into the crankcase.
Mine is the 3.5L PTU, probable similar to the 2.7L except the drain plug is not on the bottom but the side and it's smaller than T50. Hard to see what the fill side is don't think it's Torx. Still getting tools together for this. When I put the car up on ramps, it won't be level and not sure I can fill it properly. Temperatures here way cooler than middle east, was about 14F when I picked up the car couple weeks ago. thanks
