Depiry
Everything posted by Depiry
I have a 2010 with th Michelin Lattitude HP and am very satisfied,I had used the LTX on a previous Jeep with great mileage and grip in snow.I took Dunlop Grand trek St 8000 off of my Touareg,the noise was outrageous,sounded like a bad wheel bearing and replaced with Michelin lattitudes,great ride and quiet ,Have a suburban with Michelins,good tires,Marty
Filled tank,reset MPG got on HWY,over 35 miles got 26.4 mpg,Marty
Weathertech,seems to be nice,Marty
2101 Edge limited While changing the oil,12500 miles(every 2500 miles),I decided to open the lower drain plug on the tranny,slowly so I was sure it was tranny fluid,after drain I replaced plug and refilled with Motorcraft Mercon LV fluid 4.5 quarts that brought the level to mid point on the dip stick,warm.Marty
Armor All Leather Wipes... how do I fix what they've done?
Depiry replied to bcfallar's topic in 2010 Edge & MKX
Try Murphy's oil soap,Marty -
I installed Hoen Digital Xen system,No capacitors or resistors required,Have a 2010 limited with auto head lamp control,no problems easy plug and play,comes with ty wraps and shrink tubing for lamp socket connection,Marty Also came with a free pair of yellow fog lamps.
Try using a 12 volt test lamp (with the sharp probe) in series with either battery cable a light will mean a current draw,no light all clear,you can leave it on and disconnect things to make the light go out and find the problem,you can also use a multi meter set on low amps or more sensitive volts,good luck Marty
Neutral safety switch??Try moving shift lever,good luck Marty
Sorry I can't copy and paste the chart. 2oz for the condensor,Marty Refrigerant Oil Adding NOTICE: During normal Air Conditioning (A/C) operation, oil is circulated through the system with the refrigerant, and a small amount is retained in each component. If certain components of the system are removed, some of the refrigerant oil will go with the component. To maintain the original total oil charge, it is necessary to compensate for the oil lost by adding oil to the system with the new part. 1. Refer to the chart below for refrigerant oil adding amounts and methods of installation.
Driving light bulbs on SEL
Depiry replied to Picturepro's topic in Interior, A.C., Heat, Interior Trim
I just installed HOEN Xensystem 35 watt Digital HID kits,very easy plug and play,no resistors,capacitors,relays and they work perfectly. Super white light with a touch of blue,4300 K kits came with velcro mounting pads,ty-wraps,shrink tubing to cover 12volt connections,a free set of Endurance yellow lamps for fog lights,cost was $149. plus $8 for freight(priority) ,also has a 3 yr warranty on lamps and ballasts,Marty -
Unless a component is changed oil doesn't have to be added,(dryer,evap,condensor,compressor)unless a major leak has occured.Too much oil is no good as it changes the volume of gas in the system and could also damage the compressor valve plates. Marty
BRAKE LIGHT BULB QUESTION
Depiry replied to NEW2EDGE's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Do a Search for Stop Lamps there are threads on BURNT lamp sockets,Marty -
I just purchased the vehicle security system,does any one have the installation instructions,TIA,Marty It was $103 thru a wholesale account. I have tried to download the manual,but have to be a Ford employee to access the sites. I got the install manual from Code Systems,a division of Audiovox.
The Ford specified viscosity is 5W20, you used 10W30?? Marty
I have an oil extractor that I made from a 1/4 hp close coupled Oberdorfer condensate pump,they were used on small Hot Shot electric steam generators,100 psi,the pumps were used for adding water to the boiler.I have updated the hoses on the pump to those good for pressure and vacuum,the ends have quick couplers so I can change the nylon hose wands for different size applications.One end connects to a 5 gallon plastic bottle so I can monitor the amount extracted.I have pumped tranny's prior to dropping the pan without all the oil spillage.In 1979 I built an adapter for My 300CD ,and 1980 300SD the dipstick tube is tulip shaped and goes to the bottom.After pumping I opened the drain plug to get out the last drop as a test,I have used on my Touareg to change oil,power steering fluid and even have a spare pump just for antifreeze.Using an oil extractor properly should get all of the oil and sludge,Marty I have looked at several Fumoto and Fram drain valves but always had a feeling that something would hit it ,break it or open it so I never used one. # Drive carefully at all times, and if you run over any foreign object on the road pull over and check the valve for any damage or leak.
One turn signal flashing fast
Depiry replied to westin55's topic in Audio, Backup, Navigation & SYNC
Flasher sequence as to speed are load related,flashers are load specific,for 2 lamps,3 lamps,etc, if one filament burns out or breaks the sequence speed increases to tell you a lamp is out,some were designed to stop flashing if the load was not correct but SAE changed specs so that any left would flash,heavy duty 5-12 lamp flashers for larger applications are not load specific,Marty -
Are the exhaust tips chrome plated or polished stainless,barkeepers friend should clean them quickly,Marty
SILVERSTAR HEADLIGHT BULBS
Depiry replied to Mr. Westfield's topic in Interior, A.C., Heat, Interior Trim
Just installed H11 HOEN Zenon match lamps,read 285 ft candles at the highest light source ,I will put the Oem H11 Back and compare the light output,Bluish light looks good ,haven't driven yet,Marty -
Anyone smell antifreeze in their NEW Edge 2010?
Depiry replied to strenn6's topic in 2010 Edge & MKX
I am not saying that the Edge is the only car that picks up outside air odors,but it is very sensitive to the outside air,my Touareg has a sensor that switches to recirculate when offensive odors are detected and switches to recirculate when you put the car into reverse. It may be the way the air is distributed in the EDGE,Marty -
One thing I have noticed,that the air intake on the EDGE,picks up every slight odor outside,even a cigar in the car in frontof you,Marty -
I Have a 2010 Limited, 6000 miles,no anti freeze odor or smell,keep an eye on levels in coolant jar,may be a loose cap or hose if level is low,Marty Also how is the temp guage reading?? -
Yes,this flip key remote works on 2010 Edge for sure,Thank you. - artiway From E-Bay, Marty
Last 2 I bought cost $6.25 at Parts Authority,don't know where you are located,Try Walmart 5W20 Penzoil Platinum was $20.for a 5 Qt container,they may have the Fl500S, Marty
