gary712
Everything posted by gary712
no RS module.but there is an antenna plugged into the TPMS module behind the left rear quarter panel.If that is there all you need is keys that have the remote start button on it
well now you know you have a remote start. is there an antenna on the left rear glass? if so then you have a long range remote start with seperate remote fobs. if no antenna then you need remote start keys.
look under the hood for a hood switch.If it is present you most likely just need remotes with the start button for it to work
satelite radio signals do not bend loke FM radio they must have a direct view with no obstructions. that is why you lose it in a garage.under a tunnel blocked by trees or thick clouds.
Aftermarket head unit wire harness
gary712 replied to supaman's topic in Audio, Backup, Navigation & SYNC
yes that will work.if you want to retain the steering wheel controls you will need an adapter for that -
Remote Start Issue: Engine Fault
gary712 replied to Dominatron2212's topic in Alarms, Keyless Entry, Locks & Remote Start
it sounde like a transponder issue.put key in ignition without turning it try to remote start car. -
Remote start for 2008 ford edge
gary712 replied to Clarkey99's topic in Alarms, Keyless Entry, Locks & Remote Start
u can try that think of the rs as a third key. if the theft light flahes rapidly after this then the secure lock is bad. Gary -
you probably have a bad secure lock adapter. -
if it dose not come from the factory it has to be aftermarket.
there is an aftermarket kit available. metraonline.com
DVD sound besides FM transmitter?
gary712 replied to bd1980's topic in Audio, Backup, Navigation & SYNC
the using of FM modulation for the dvd sucks. If you installed these yourself you will know where the junction box is. this is where the two dvd's connect together and has the power wire also. If this is the newer version it has a 3.5 headphone jack on the side you can use and plug that into the aux input or get an adapter and plug it into the red and white RCA's. If you don't have that 3.5 jack you can use a headphone from one of the headrest DVD's and do the same. Gary -
I have upgraded my iphone 5 to a 6plus paired easily downloaded all contacts. I get my texts It works perfect w/MFT. I use T-mobile No more AT&T
problem solved. texts are back . thanks for the tip.
I have a 13 LTD and just got a iphone 6 plus. I am not getting texts. Am I doing something wrong?
Ford Remote Access
gary712 replied to tomm1079's topic in Alarms, Keyless Entry, Locks & Remote Start
Enjoy it. -
the ltd edge came with a subwoofer. so yes there should be something back there
Ford Remote Access
that website is for adding cars with existing pin number to your acccount it does not generate pin number -
Ford Remote Access
you can install it yourself.It is a pretty simple install in the edge. It just plugs into the TPMS module in the left rear panel. But the problem is you cannot program it and generate the pin# without it being connected to a ford computer (IDS) -
Installing remote wire for amp
gary712 replied to ravishingrocket's topic in Audio, Backup, Navigation & SYNC
your only other option is using a switch in line with the remote turn-on wire
