cold air intake problems
mikeblake710
i installed a cold air intake and after a solid month the engine light went on. took it right to the dealer and he said its causing computer problems and i should take it off... :l should i get a tune or just leave it on?? i really don't want it off i can't stand the sound of the v6 without it.. lame.
what intake are you running? an improper sized maf housing will cause the maf to read incorrectly thus cause your fuel trims to be rich or lean. once the car has to add or subtract so much fuel to hit the targeted air fuel ratio it may trigger a check engine light, usually it will say, lean off idle, lean on idle, rich off idle, or rich on idle. i'd make sure you have the correct intake and everything is hooked up correctly. i tune would definitely help it though.
