Vleds V3 Triton Gen2 Type 2 Switchback - Hyperflash Problem
Hello,
I received my new LED VLEDS is the second generation. I temporarily install the LEDs to make a test and I'm left with the problem of fast flashing. I test with both controller. I remove the 5A fuse and still the same problem. Do you have a solution for me?
See Video
Thank You
Best Regards
Sorry for english i'm french ++
Vleds QuickFlash.MOV
Hello,
See Video
Thank You
Best Regards
attachicon.gifVleds QuickFlash.MOV
Sorry to hear the 2nd generation of the V3 Tritons don’t work any better than the 1st generation, which I tried. The V3s are quite bright and I was hoping they’d fix the problem in the 2nd gen. Please let us know if you resolve the issue.
Hi,
Reply from VLEDS Support:
Hi,
OK we know about this issue. The new Fords have a new computer controlled lighting system and we are trying to figure out the solution. You have all the right connectors so no need to worry about base type. We are trying to get one of these cars in here to find the solution. If you can just hang in there we will get it figured out and email you as soon as we know more. Email us anytime for an update.
Thank you,
Customer Support
Edited by Labol
Hi, today i have reply from Vleds.
Hi,
We have solved the issue with the Ford Edge. We have a new adapter that plugs in line with the base adapter and V3 control box.
http://www.vleds.com/v3-triton/parts/10-up-ford-f150-edge-adapter.html
This will solve all hyperflash and white staying on issues. This is for GEN2 system only. If you have GEN1 system please let us know and we will make a special adapter for you.
Thank you,
I'm order it and wait
Edited by Labol
