Gas milage drop after...
Kitulu
Prior to changing my sparkplugs, I was getting between 15-16 mpg in city driving, and 23-24 on the highway (@75-80mph) After changing my plugs two weeks ago, my city milage is now hovering around 13 mpg. I used NGK platinum plugs, gapped at .054, and changed the air filter and PCV valve while I was there. The old plugs were showing a gap of .080, give or take. Why has my milage gotten worse?
I did not disconnect the battery, and I double checked the boots on reinstallation. The engine is running fine. After reading the manual, it states that the MPG meter should be reset while travelling at a constant speed for three minutes. I had reset it just prior to going home from the gas station. I reset it today on the way to work and it is reading 18 MPG now.
