olredhead Posted October 18, 2013 Report Share Posted October 18, 2013 07 FWD 90k miles, sounds as if something dragging when the rear tires are rotated while on jacks. Shouldn't a rear wheel freewheel with only a slight drag from the main brake pad ? Emergency (parking) brake functions fine. thanks for any info Quote Link to comment Share on other sites More sharing options...
surferd15 Posted November 6, 2013 Report Share Posted November 6, 2013 True, can be your parking brake or your hubs are that bad that you can hear it while rotating it by hand. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted November 7, 2013 Report Share Posted November 7, 2013 As mentioned, check the bearings in the rear hubs along with the e-brake being adjusted properly. Although it works, it might be making slight contact. Could also be run out on the discs. What condition are the pads and discs? Quote Link to comment Share on other sites More sharing options...
Mudnut Posted December 2, 2013 Report Share Posted December 2, 2013 I was getting a howling sound while on the highway in my 2008 Edge, filly sorted out the problem, the rotors and the ember brake pads had to be replaced, my mechanic said to use the ember brake every now and again to keep them from getting too much rust built up, thats what was causing the noises for me... Quote Link to comment Share on other sites More sharing options...
