Cabdog47 Posted April 28, 2014 Report Share Posted April 28, 2014 Hello! I am very new to these forums, and I am hoping for advice on the best way to tint or darken lights please? I read one forum where someone used Plasti-Dip, but the results seemed to dim the lights and that does not sound like a good way to go. I'm hoping to do the tail lights first. Any advice please? I looked around these forums but not finding the best ways to do this. Any information would be very appreciated please! Thanks in advance! Quote Link to comment Share on other sites More sharing options...
akirby Posted April 28, 2014 Report Share Posted April 28, 2014 Please don't tint the headlamps or taillights such that it diminishes the light output. It's dangerous and illegal. If you're just doing the non-lit areas then paint or plasti-dip would work. Quote Link to comment Share on other sites More sharing options...
Cabdog47 Posted April 29, 2014 Author Report Share Posted April 29, 2014 Please don't tint the headlamps or taillights such that it diminishes the light output. It's dangerous and illegal. If you're just doing the non-lit areas then paint or plasti-dip would work. Thank you. I have no intention to use PDip for the lights after research. I would like to keep the front stock. Any advice on how to darken/tint the tail lights the Best way please? I'm hoping to give them a darker(slightly?) appearance that most importantly, does not impede on function of the lights (dimming) please? One again, sorry for the newbie questions or if this is even possible. Thanks a Ton! Quote Link to comment Share on other sites More sharing options...
bdevillier19 Posted April 29, 2014 Report Share Posted April 29, 2014 (edited) VHT night shades is what i have used in the past. the more you put on the darker it gets. do both tail lights at the same time and side by side to get them as evenly coated as possible. the night shades dries in a flat finish so be sure to clear them. Edited April 29, 2014 by bdevillier19 Quote Link to comment Share on other sites More sharing options...
pjsockett Posted April 29, 2014 Report Share Posted April 29, 2014 I did mine with a transparent vinyl. It looks great but I would not recommend it if you have never done it before. The '11+ tail lights are rather difficult because of the deep crease in the middle of the light. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 29, 2014 Report Share Posted April 29, 2014 Thank you. I have no intention to use PDip for the lights after research. I would like to keep the front stock. Any advice on how to darken/tint the tail lights the Best way please? I'm hoping to give them a darker(slightly?) appearance that most importantly, does not impede on function of the lights (dimming) please? One again, sorry for the newbie questions or if this is even possible. Thanks a Ton! The only way to tint them without diminishing light output is to switch to brighter bulbs to compensate which causes other problems with wiring and sockets and heat, etc. Quote Link to comment Share on other sites More sharing options...
kc300c Posted May 8, 2014 Report Share Posted May 8, 2014 A multi layer spray coating with a professional tint finish and quality clear coat is best method and will last the longest. I don't mean using the tint out of the can. Unless you have your own paint spray equipment and are very good applying even coats, you will want to have a paint shop do it for you. Prepping the lights is the most important step and two coats of quality clear coat at the end is too. We use a great paint shop to have the smoke tint applied to our SPORT LED Taillights. Film will become scuffed and hazy over time due to washing and UV. Quote Link to comment Share on other sites More sharing options...
